Fueling & Injection - ID 1000's or???
jak2908
06-19-2012, 01:41 AM
Turbo car, probably gonna go with a walbro 400 and will be going e85. My tuner says to go with the id 1000's for the drivability of them for cruising and part throttle and such. He says anything else gets kinda stumbly. He is using hp tuners. What have you guys experienced? Is there other options that perform similar? Just that a $1000~ on injectors kinda hurts when I thought Siemens would be ok
http://ls1tech.com/forums/pcm-diagnostics-tuning/1546951-there-such-thing-most-easily-tunable-injector.html
jak2908
06-19-2012, 05:23 AM
Do they make the fic's for ls1??
http://fuelinjectorconnection.com/shop/viewitem.php?productid=21
I just picked up a set last week. They supply tuning data with them too. Give Jon a call.
jak2908
06-19-2012, 07:47 AM
Cool thanks a bunch. Any idea how they compare to the ID's? I can't say I know much about injectors..
http://ls1tech.com/forums/fueling-injection/1548454-injector-comparison-bosch-fic-version-id-version.html
Read post #2
ls2 goat
06-19-2012, 09:40 AM
ID and FIC are the same thing. Save your money and go with FIC.
jak2908
06-19-2012, 10:40 AM
Same thing?!
ZL1Killa
06-19-2012, 07:03 PM
Same thing?!
On the 1000cc they use the SAME part number.
On the 725 they use a different pn. On the 850 same part and 2000 same part
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
