General LSX Automobile Discussion - need a cable driven throttle body
Houston_t
06-19-2012, 06:06 PM
which cable operated throttle body can i use on my 08 LS2 its out of a trail blazer ss and im using the stock truck intake
Juanmiguel
06-21-2012, 03:46 PM
I think it depends on the number of screws it has for the TB, 3 or 4.
Houston_t
06-26-2012, 08:07 AM
Mines has 4
bww3588
06-26-2012, 09:09 AM
Most any company makes a 4 bolt cable tb. I have a 92mm bbk 4 bolt cable tb. It was less than 300 shipped from s&k speed.
Houston_t
06-26-2012, 09:15 AM
Ok thanks for the reply. Looks like I may just wind up switching to a car intake since I'm going with a new project car, want to have the option of mounting the motor up under a stock car hood if need be
Rtzracer
06-26-2012, 10:50 AM
The truck is designed for torque not horsepower. Definitely would swap it out.
bww3588
06-26-2012, 10:53 AM
Either way, car or truck intake, they have the same flange, so it will work on either manifold.
Houston_t
06-26-2012, 10:59 AM
Will the LS1 car intake and throttle body work on a LS2 ? I see that they have different size throttle body's
bww3588
06-26-2012, 11:15 AM
Yes, the Ls2 intake is only marginally better than the ls1 intake. Which is lame. The Ls2 style truck intake is actually very good in comparison. It is right on par with the ls6 intake.
If you need it to fit under a car hood, I would get an ls6 intake which is a good improvement over the junk ls2 intake.
NEXRACE
07-11-2012, 08:30 AM
did you decide what intake & tb you are going to use?
Houston_t
07-11-2012, 08:36 AM
Yea going with the LS1 for now, got a good deal on a setup and it's all my budget will allow. Motor is all stock, if and when I port the heads and go with a bigger cam I will look into changing it then
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
