Drag Racing Tech - Solid or Poly trans mount
View Full Version : Solid or Poly trans mount
Money1
06-19-2012, 09:16 PM
I have a TH350 and solid motor mounts
Which is better solid or poly for my transmisson mount
95killerz
06-19-2012, 10:24 PM
A solid trans mount can break your tail housing. Poly mount should be fine
fenton06
06-19-2012, 11:02 PM
Poly, for reason above.
jthunderz28
06-20-2012, 12:15 AM
If you are not a hardcore track guy, i'd go with the stock GM onebrand new on Amazon for like 50 bucks.
Took away a lot of my interior vibrations.
However if your car is a strict track car, seems that most people i know have luck with poly.
RacerXLs1
06-20-2012, 06:54 PM
JL couldn't of said it better,, poly!!!
Longbob
06-20-2012, 10:38 PM
Poly at the very most. I have solid motor mounts and run a factory rubber transmission mount on my stocker.
STOCK1090
06-21-2012, 07:19 PM
Solid engine mounts and factory trans mount.
Firehawk441
06-22-2012, 03:54 PM
Only way a solid one is even a viable option is if the car is motor plated and mid plated... and the transmission has an aftermarket case so it's built to handle that.
Ploy will suit you fine... no need to go any further.
YES...:rock:
