ARP head studs...did you use teflon sealer?
Old 03-31-2004, 05:17 PM
BoneStock's Avatar
Default ARP head studs...did you use teflon sealer?
Do the LS1 block bolt holes run into the water jackets? If so, what kind of thread sealer did you use?
Will
Old 03-31-2004, 11:38 PM
Chris99WS6PWTMET's Avatar
No thread sealer required. After head removal just make sure you get all of the coolant out of the holes. A shop vac with a small hose taped to it works well. Apply some oil or moly and thread them in with an allen wrench.
Old 04-01-2004, 07:53 AM
SAM98WS6's Avatar
nope..arp moly lube only
Old 04-01-2004, 04:33 PM
smokin' joe 00 ss's Avatar
[QUOTE=SAM98WS6]nope..arp moly lube only[
Ditto!
