joastarlet
06-20-2012, 03:17 AM
I have this katech engine that is for my race car, and i want to know how high i can rev it? and maybe what i can expect from running it on e85 with a good tune.
And if 6400 is the absolut max, then what mods do i need to rev it higher.
I am running a Mid valley 4 speed gearbox.
CR: Unchanged from stock. LS2 should be about 10.7:1
Injector size: Stock LS2
Cam: 227/235 @ .050, .361/.365 lobe lift, 113LSA, 1.7:1RAR
RPM limit: 6400
Power: 509@ 6600, TQ: 447 @ 5200 (actual, not estimated)
-Street camshaft, mild lope
-PSI springs
-Trend pushrods
-CNC-ported heads
-C5-R timing chain
-Katech oil pump
-Katech aluminum valve covers, powdercoated red with Katech logo inserts
-Katech coil relocation kit with black wires
-Katech billet belt tensioner
Specs:
58x/4x triggers
90mm edelbrock trottlebody
Corvette damper/water pump
Corvette oil pan
best regards
Joachim
RPM limit: 6400
-PSI springs
-Trend pushrods
-CNC-ported heads
-C5-R timing chain
-Katech oil pump
Specs:
58x/4x triggers
Corvette oil pan
best regards
Joachim
