How do I hook up my dyno jet 2 wideband to hptuners
Hello,
I just received my dyno jet wideband, and hptuners pro today. I know that I must hook up the red and black wire to a 12V cigarette lighter correct?? I'm unsure on what I must wire up from the wide band to the hptuner interface. There's 8 different colour wire, as well as two plug in adaptors on the wide band, do I have to wire in all wires to the green connection to the hptuners and if so in what order, or do the plug adapters plug directly into the the hptuners interface? There's also white and violet wire's that must be used.Any help would be greatly appreciated, as my cars down until I get this figured out.
And as you can tell I'm a little green in this area lol.
Thanks
Thanks
You have to power and ground the wideband and to log the wideband you use the 5v reference and plug that into the EIO plug in. On your corresponding spot on your table display input the dynojet wideband pid. If that doesn't log correctly, create your own with the supplied values.
