New LS1 Owners - Newbie Tech - Iac epoxy mod
Shane Thrash
06-20-2012, 08:18 PM
I have a 408 w heads cam and fast 90 intake and t body I have a speed d tune having idle problems was just wandering if anybody has heard of filling the iac hole and drilling out a smaller hole to control the erratic idling or and suggestions
jimmyblue
06-21-2012, 10:17 AM
I've been down this road with the stock TB and making
the hole smaller than factory-stock does not help - it
hurts, by making the IAC "wind up" trying to get air that
won't come.
Look to low-end airflow accuracy -> mixture for your
stability problems. Tuning to stoich on the wideband is
not going to be real accurate with a big cam. You have
to play with it, and see what indicated AFR idles best.
And then keep closed loop from ruining it, if you're
trying to keep closed loop operation.
HioSSilver
06-21-2012, 11:40 AM
Shane is your car a auto or 6m? Do you have tuning software? What exactly is it doin?
Sales3@Texas-Speed
06-26-2012, 03:17 PM
+1 on not doing the epoxy mod, you should be able to fix this issue in the tune.
2win_SS
06-27-2012, 03:25 AM
As soon as that epoxy falls out of place guess where it goes....
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
