Holly High Rise LS1 Intake vs Fast 102???
As the title states....which one will perform better on a...
383 LS1
Afr 205 heads
comp cam 239/247 590 to 600 lift Not 100% on the cam specs
11.0-11.5 compression
pump gas
1-7/8" headers
also looking to change the heads out to something in the 230cc range....maybe AFR 230's or PRC 227's.....
What would be the best combo "you" would build?
383 LS1
Afr 205 heads
pump gas
1-7/8" headers
I think the Holly is like a tunnel ram and would feed your motor better at high RPM. The fast will be better down low for street applications I would think and you won't have clearance problems.
Never had the Holley, but I absolutely love my Edelbrock proflo xt... Seems to do several things, give more top end, while broadening the entire powerband and smooths out the idle some on a bigger cam...I'd also ditch the MAF and run in SD mode.
The true measurement I took on mine was 10.75" st the top of the tb mount to the lowest part of the intake flanges.....I thought I had read the Holley was just over 9" tall, but that might have been with the top plate unbolted.....lol i never been wrong before!
