Street Racing & Kill Stories - Cobalt SS/TC Vs LS2 C6 Vette
View Full Version : Cobalt SS/TC Vs LS2 C6 Vette
M29_Formula
06-21-2012, 09:41 AM
http://www.youtube.com/watch?v=W7MJyR9UPTI
Just a friendly run to see how my Cobalt would stack up against a bone-stock 6-speed Vette at high altitude. In the dig race I get out on him by about 3 cars before I shut down around 110mph. In the roll race I get about 4 or 5 cars on him and shut down at around 115mph. Hopefully going to run again if the Vette does some mods.
hugger1975
06-21-2012, 09:45 AM
Remind us of your mods.
Can't see sig ;-)
M29_Formula
06-21-2012, 09:50 AM
Can't see sig ;-)
- CHEVYCOBALTSS3 Full E85 Tune @ 25psi (tapers to ~20 @ redline)
- ZZP 3" Catless Downpipe
- ZZP Bolt-In FMIC
- Hahn CAI
- ZZP Rotated Trans Mounts
- Driver mod (except shifting 1st to 2nd, no NLS -- too scared to break tranny)
Street tires, stock everything else.
V8EATR
06-21-2012, 09:52 AM
Not surprising given the altitude. Nice kill.
ramairetransam
06-21-2012, 10:45 AM
those cobalts move out , i love it . Gm did good on that engine .
marc97taws6
06-21-2012, 11:00 AM
Nicely done. Have to love what a few bolt-ons, E85, and added boost will do to a factory turbo car
HioSSilver
06-21-2012, 11:22 AM
altitude compensators.......FML
Good kill
hugger1975
06-21-2012, 11:42 AM
Man I wish I had the slobalt when I lived in CO.
My cammed hugger ran 13.3 there :lol:
And I wana hear more about the rotated mounts.
NLS 1-2 is damn near impossible stock FTL.
black06g85
06-21-2012, 11:52 AM
these tc's are starting to grow on me, I'm thinking of picking one up as the new daily driver in a few months, put my cobalt back to the turbo'd fire breathing monster it once was.
M29_Formula
06-21-2012, 12:56 PM
The rotated trans mounts are stiffer and also correct the stock CV shaft alignment angle that causes wheelhop that leads to broken axles. My car WILL NOT wheelhop since I installed the mounts -- it used to before and I'd have to let out to avoid breaking shit.
And NLS 1-2 was easy when I was GMS1. It got hard when I got tuned because it's hard to time it with the tires spinning. I've done it once and it works, but I'm not testing my luck. :lol:
hugger1975
06-21-2012, 06:35 PM
I always seemed to pass the rev spot or spin on the 1-2 damnit.
I never ever miss the rest.
And I hear ya on hop.
I can join the hydrolics crew at the drag strip :lol:
Balt2nv
07-02-2012, 03:09 PM
Wish i could run E85 on mine.
TheBlueKnight
07-02-2012, 03:56 PM
Nice runs, your car is fast! We race at around 7,000ft down here at my local track and I can barely squeeze out a 13.7 @107mph. How much is E85 per gallon?
Juanmiguel
07-02-2012, 06:00 PM
13's is really fast at that altitude. I only did mid 14's on a bone stock 2000 T/A @ 5000ft and low 14's on a pullied/cammed/intercooled GTP.
M29_Formula
07-03-2012, 09:27 AM
It's like $3.22/gal here. I'm going back this Friday with some minor changes to the setup -- shooting for somewhere around a 12.7-12.9. If I can retain my trap speed and drop my 60ft down from a 2.1 to a 1.9 or even a 2.0, I've got 12's in the bag. :D Not bad for a gay 4-door rental car with a couple intake/exhaust mods and a tune.
DA at the track this Friday evening should hopefully cooperate and drop below the 8000ft mark as it cools down. Crossing my fingers.
willizm
07-03-2012, 09:47 AM
e85 is a beautiful thing providing you have a station near by. Hugger1975 needs to switch to the corn sauce some day.:nod:
OP, are you on stock fuel system or did you upgrade any of that when you converter over to e85?
M29_Formula
07-03-2012, 09:59 AM
100% bone stock fuel system. The LNF uses GMs SIDI Direct Injection fuel system which uses a lift pump in the tank and a mechanical high pressure fuel pump and injectors much like a diesel. The stock fuel system supports about 400whp on E85 and a little over 450whp on pump gas before you have to either stroke the pump with a larger fuel pump lobe on the camshaft or add a 5th injector setup. So unless I goto a larger turbo, I won't have any fuel system woes.
willizm
07-03-2012, 11:12 AM
What does your fuel economy look like after the switch? Mine is shit, but slightly better than a srt8 jeep. Lol
M29_Formula
07-03-2012, 11:22 AM
It's terrible... about 18mpg city and 22mpg highway. Used to be ~23mpg city and a little over 30mpg highway on 93 octane. The power increase is worth it though. That and premium is about $3.70/gal here right now, so it costs roughly the same per mile to run E85.
hugger1975
07-06-2012, 08:53 PM
Hmmmmmmmmmmmmm
marc97taws6
07-06-2012, 10:11 PM
Corn it up, Hugger!
Use some of that corn sauce us Iowans provide ya'll with :P
callmedoc
07-10-2012, 06:15 PM
No offense, but can that guy in the vette drive? As much as I respect modded cobalts, there is something wrong here.
GXPPOWER
07-10-2012, 06:22 PM
do you not understand how much 8600 DA will effect a NA engine? the Cobalt has a Huge advantage being FI and using e85. he trapped 110 mph in 8600 DA. DA corrected would be roughly 12.47@115 MPH
if a stock NA car ran the exact 13.1 his corrected DA time would be 11.58@122
callmedoc
07-10-2012, 06:36 PM
Ive just seen so many people at the track who make these Vette's look bad. A good driver makes a HUGE difference w/ these cars. Just my experience.
Good kill OP
hugger1975
07-10-2012, 07:39 PM
GHP nailed it though.
I was pissy when my cammed hugger ran 13.3 in Colorado.
Damn Sti with minimal boltone was runnin 13.0
Grrrrrrr
jbs02somws6
07-10-2012, 09:52 PM
:werd: N/A cars lose 2-3% percent of their hp for every thousand feet of elevation.
T.Man
07-10-2012, 10:18 PM
Depends on how its tuned for the ethanol and whether or not you're running full on e85, which IMO, isnt necessary with DI to take full advantage of the knock suppression. I found that my car was fastest running a mix of 25-30 percent E and 87 octane :D
Car runs hard though buddy! Nice work.
willizm
07-10-2012, 11:05 PM
TMan, it says your location is in the desert? Which one? Anywhere around Vegas?
bamaballa205
07-10-2012, 11:48 PM
Nice kill OP. Wish GM would've done the Pontiac G5 in a T/C version.
Balt2nv
07-11-2012, 12:24 AM
Could always have built a 2.2 or 2.4. ZZP makes a nice turbo set-up for the 2.4
TheBlueKnight
07-11-2012, 12:33 AM
It does suck. My T/A traps 106-107mph at 6800ft and in Sacramento at near sea level (800-1200ft) I trap 113mph and 114mph at close to 0 DA. At 6800ft I'm at the top of third through the traps and at sea level I'm deep into fourth at the end of the quarter.
T.Man
07-11-2012, 02:38 PM
Arizona
