Fueling & Injection - What fuel injectors for an LS1 intake with an LQ4 wiring harness?
osborneconst
06-21-2012, 10:11 AM
I went to install my LS1 intake on my LQ4 in my 2nd gen camaro swap, and realized that the injectors out of the truck intake are to short for the LS1 intake. Is there an injector I can use that uses the same connector as the truck injector, or am I going to have to modify my truck harness to fit a car injector?
FICINJECTORS
06-21-2012, 12:41 PM
use ls1 injectors and this wire adapter is the cleanest way
http://fuelinjectorconnection.com/shop/viewitem.php?productid=177
osborneconst
06-21-2012, 12:46 PM
Thanks! What injector should I get? A stock one from a 98-02 camaro?
FICINJECTORS
06-21-2012, 03:27 PM
Thanks! What injector should I get? A stock one from a 98-02 camaro?the lq4 uses a 26 @ 58psi.. the stock 98 is 28.8 09-2000 is 26.6 2001 up is 28.8 so get pn 0280155890 that came in a 99-2000 which will be a good match as long as the lq is stock. we have them rebuilt for 189 a set.. new for 330 a set
LQ4-E39
11-16-2012, 07:35 AM
is that the price ($10.95) for one connector only?! or is that for the whole set of 8?
LQ4-E39
01-02-2013, 09:00 AM
anyone?
LS1MCSS
01-04-2013, 07:54 AM
is that the price ($10.95) for one connector only?! or is that for the whole set of 8?That's going to be for one. You can get a complete set of LS1 connectors on ebay and solder them in. It would look much cleaner than using the adapters.
lsxtreme17268
01-04-2013, 10:30 AM
Could get the ones you crimp on. They are like the factory ones so there is No splice at all
FICINJECTORS
01-04-2013, 12:15 PM
we have the ends for 4 bucks each, connector, pins, and seals
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
