Generation IV Internal Engine - Stock rockers Afr heads?
View Full Version : Stock rockers Afr heads?
tommycompton
06-21-2012, 12:56 PM
Getting a million different answers on the subject with searches and would like a more difinitive answer if possible.
I ordered a set of 72cc 230 Afr heads for my ls2 (a lower compression blower set up) I am wondering about using the stock rockers with a stock cam and the use of bronze valve guides on the AFR heads. Is guide wear only a problem with higher lift cams; bronze guides and stock rockers?
I was planning on doing a trunion upgrade; but have also heard mixed reviews on that also.
If I went with roller rockers my plan was Yella Terras.
Of course stockers are cheaper; but I don't want to save a buck for dependability.
Any thoughts would be appreciated.
tommycompton
06-22-2012, 05:34 PM
Nothing? Where are the people in the know?
I know it's been brought up before' but the answers aren't very cut and dry.
NVR_SPDS
06-22-2012, 05:54 PM
Shoot Tony Mamo@AFR a PM on here. Theres no better source for infor, then the man himself!
He set my stock rockers up on my 205s for me. I just dont remember which guides are in them.
tommycompton
06-22-2012, 06:35 PM
He was mentioned in another thread I made before. I will give him a message.
Thanks.
99Bluz28
06-22-2012, 10:25 PM
If the lift is over .600" you want RRs, under that stock rockers are fine.
tommycompton
06-22-2012, 10:40 PM
Yeah when i decide to do a cam it will be for a blower so it will never be high lift.
I wasn't sure if bronze valve guides would be a factor with stock rockers.
From what I gather AFR heads share stock geometry; so I was assumming it would be fine to run the stockers without worring about premature guide wear.
Just want to be 100% sure.
