Cadillac CTS-V - Nitrous question
View Full Version : Nitrous question
brizzle
06-21-2012, 04:27 PM
A friend of mine has nitrous kit that came off his camaro with a LT1. im wondering if that will work on 04 v? any info is appreciated
vmapper
06-21-2012, 04:28 PM
There is no 'specifics' which nitrous could or could not be applied to another vehicle. A kit will merely come with x amount of feet of braided line, one or two solenoids, couple relays, some x amount of wire, a tank, brackets etc.
Its basics... tank, lines, electronics, nozzles.
itsslow98
06-21-2012, 09:37 PM
Unless its a plate kit it will work fine, but just make sure you follow the recommended jet sizing for your vehicle(which still may be off). They are different for some vehicles.
brizzle
06-22-2012, 08:50 AM
o plate kits dont work on v's?
vmapper
06-22-2012, 09:18 AM
Im already nervous for the engine -
Is it a wet or dry kit, you will have to be intuitive and make your own injection nozzle setup in the intake pipe or manifold.
Are you going to use a RPM switch? - you better be
a fpr hobbs switch to open when fuel pressure drops.
Full throttle trigger
These are just a few implemented pieces one must consider.
I like to make the nitrous system dummy proof (as in remove any human error). Once in place, nothing will go wrong, except for a bad tune.
brizzle
06-22-2012, 04:07 PM
I think i'm gonna leave it of for now until i can talk the wife into letting me put it on lol
vmapper
06-22-2012, 06:19 PM
I prefer the tell wife after install occurred - "Oh, sorry, how did that get in there...(shrug)"
06vLo
06-23-2012, 12:15 AM
bwahahahahahaha aint that the truth.
brizzle
06-23-2012, 10:16 AM
Hahahahahaha if only it was that easy
adanieljohnson1
06-23-2012, 06:55 PM
Who said the wife has to know? Just tell her all 04-05 Vs are fast as shiat...
itsslow98
06-24-2012, 09:57 PM
Plates work fine just not one off an LT1 kit. Also the plates on our cars push the intake closer to the radiator so you may have to trim up the intake tubing.
