Fueling & Injection - Siemens/ Deka 80# from FIC
10secondZ
06-21-2012, 05:35 PM
I bought some deka 80's from FIC and got them in the mail. they came with a flow sheet, but I can't find anything on short pulse or offset voltage? Anyone have that info? btw fic is awesome!! super fast shipping!!
Carter
10secondZ
06-21-2012, 10:50 PM
I have the banish dvd and the info for the ford motorsport 80lb injectors, would that be the same info?
Your best bet would be to call Jon at FIC today. He seems to be around to answer calls any time I have called. I imagine he would email you the rest of the data if he has it on file.
oange ss
06-22-2012, 09:23 AM
I thought it said SD in the DVD ? Thats the data I used.
10secondZ
06-22-2012, 09:31 PM
Correct :) did you use the kpa vs flow rate listed in the tables? or was your number higher?
oange ss
06-23-2012, 01:54 PM
I used the data that was in the table
ZL1Killa
06-24-2012, 08:26 AM
call Jon and ask for the data (have him look up your order) ; if he can't get it to you right then we can certainly get something to you in the following few days. Are those injectors disc, pintle, or ball ? To get it running nicely, you can lower your stock offset table to where the values are roughly 1.4msec from 10.5v up to the highest voltage in the table, below 10.5v the msec should increase a decent bit.
also, short pulse adder (range it from 0.6 to 0.02)? or short pulse limit (1.0)? at least until we get some solid data for ya.
99VetteFRC
06-24-2012, 10:58 AM
I bought the same injectors from Ebay and did not get any flow sheets with them. I would really appreciate any info on these injectors as well. Here is a link to the Ebay auction where I bought them.
http://www.ebay.com/itm/290680434159?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
10secondZ
06-24-2012, 01:43 PM
Thanks!
I have the hard data for these injectors now. thanks!
Carter
99VetteFRC
06-24-2012, 07:46 PM
Thanks!
Carter
Would you care to share your data? I would greatly appreciate it.
99VetteFRC
06-25-2012, 11:20 AM
Found this Info on the injectors at the web site.
http://siemensdeka.com/specsheets/FI114992.jpg
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
