Drag Racing Tech - Race Weights?
View Full Version : Race Weights?
Zero4488
06-21-2012, 08:55 PM
I am trying to get an idea of a typical race weight for a fourth gen. Looking for some input from the lighter guys...trying to find out how light you can make one.
-Dave
11SECSS
06-21-2012, 09:27 PM
I have mine down to around 3260 with me in it...
89ROC-Z
06-22-2012, 12:42 AM
I'm thinking my TA has a good 360 pounds removed not including the weight reduction of the drag wheels, but idk what it weighs exactly lol
HioSSilver
06-22-2012, 07:52 AM
You should really be looking at car weight because drivers can very over 100lb. My car can be as little as 3000lb(still complete w/ ac, cruise, all seats looks like a normal f-body) and I weigh 160.
ATVracr
06-22-2012, 08:07 AM
under 2700lbs race ready without driver.
BAIN
06-22-2012, 10:02 AM
Depends on what you want to do with the car. I have seen weights from 3600 to 2800 with driver. There is a lot of good info on here reguarding weight reduction if you spend lots of time searching and reading every post on the subject.
Currently my car is sitting at 2900 lbs without driver. I'm shooting for 2700-2750.
WhiteLTone
06-22-2012, 12:03 PM
2680 last year 2850ish with driver. Since then switched to slick over radials, swapped the posi for a spool, ditched factory fans for slimfan. But also added n2o bottle and a fullsize battery in the rear.
Firehawk441
06-22-2012, 04:06 PM
Getting to 3100# raceweight is fairly easy. After that it becomes more of how much $$$ you want to spend and of course the time and effort.
Pseudonym
06-22-2012, 06:27 PM
What is the easy way to get it to 3100lbs? I need to start trimming the fat on my car.
djsanchez2
06-22-2012, 07:55 PM
How did you manage such a low weight while keeping everything?
RacerXLs1
06-22-2012, 08:01 PM
Ive been searching and cutting so I hope I get there.. :drive:
Tally TransAm
06-22-2012, 08:37 PM
3445 with me and half tank.
took out some more shit to offset the iron block thats going in
+badss+
06-22-2012, 10:49 PM
lol i so need to start cutting weight from mine im expecting around 3650 race weight lol.
HioSSilver
06-22-2012, 11:33 PM
Lots of little this's and thats ;). To look at the car you would think it was full weight or near full weight. Still has inner bumpers, windshield washer tank, abs and sound deadening.
Reject
06-23-2012, 12:14 PM
trying to figure out your "creative weight reduction"
WhiteLTone
06-23-2012, 12:27 PM
There is pics of it in other threads. He lightened alot of the factory parts. Looks clean and creative
djsanchez2
06-23-2012, 12:34 PM
Care to elaborate? I would love to follow suit. My SS is going to be one heavy bitch! LQ4, 4l80e, 9" rear! Please enlighten us with your wisdom :)
spaulding
06-23-2012, 03:07 PM
Im 3006 with out me init with almost a full tank. Th400 9in ls1 strange brakes full tubular susp strange shocks pinto rack, billet specialtie wheels and a wolfe ms 6pt. I rewired the car from scratch and kept it all to a minium still have a 10in thunderform sub ozite carpet and corbeu seats... Ill be doin alot of cutting and welding overthe winter in creative ways and changing to a moly 10pt with moly sfcs and kirkeys and a bunch of lil things i just didnt wanna do so i could get back to track quickly
Taubr Unit
06-23-2012, 03:51 PM
Click my build thread in my sig, I cut a lot out and spent a decent amount of money as well..
Outlaw666
06-25-2012, 09:20 AM
Im not sure where my weight is at but all that I have removed from the car will go towards my goal race weight of sub-3300lbs...that's with a iron block, turbo (a2w) and cage (8.50 for now but maybe a 25.5 in the future) I'd imagine a na/n2o setup can really get down there in the sub-3k lb range, good luck!
studderin
06-25-2012, 09:15 PM
under 2800 :secret2:
Coach 02 A3 Z/28
06-26-2012, 09:49 AM
Race weight of 3050 with me in the car. I am 253 LBS.
Coach
5.3LJimmy
06-26-2012, 09:36 PM
I have my trans am down to 2925 with me in it and I'm 210lbs. Single kirkey seat, Vfn pin on Hood, strange brakes, madman rack, speedglass f&r, minitubs, th350, 12 bolt with a spool, and hardtop conversion.
I pulled just about everything listed in the weight reduction sticky out of the car. I still have functioning headlights, door bars, and a horn for now.
Up front I have a UMI kmember with PA control arms. All the rear stuff is from Madman except the BMR drag bar.
WhiteLTone
06-26-2012, 09:46 PM
thats light! how much did you end up saving by going w/ rear drag brakes and steering rack? i still have factory steering rack, column, and rear brakes. ive been considering doing the door panels and a few other things. i have ttops too and i hate them, but the 6liter conversion targa top is soo much money.
gmtechnician
06-27-2012, 12:44 AM
just wondering does anyone know what these cars weight factory i have a 98 trans am
WhiteLTone
06-27-2012, 06:22 AM
3400-3600 depending on options
5.3LJimmy
06-27-2012, 10:57 AM
It has been a few years, so I don't remember exactly how much the brakes saved. I did all four corners at the same time and I believe it was 110-120lbs all together. This is using Strange brakes with the Racecraft front spindle that use the third gen brakes and the Racecraft manual master cylinder. Switching from power to manual steering is around 25lbs savings when you include the pump and lines.
I still have the factory door panels and steering column. All interior plastics and center console are in the car as well. I have some Ozite carpet to put in but I'm waiting to upgrade from a MS 6 point to a CM 10 point before installing it. The 2925 was with no carpet in the car.
I went to a junk yard and cut a hardtop roof panel from a 96 Camaro. I was tired of the paint bubbling on my sail panel and figured if I was going to go through the hassle of swapping it I should delete the t-tops. I used the roof panel, the door seals, and cut the metal that runs at the top edge of the door opening from the Camaro.
chas010
06-27-2012, 02:46 PM
3030 with me in it.
WhiteLTone
06-27-2012, 07:25 PM
Thanks 5.3Jimmy - my car has same weight reduction as you pretty much, last year 2680 w/o me in it, this year maybe about the same w/ new n2o stuff. I'll probably do door panels, wiring harness, front radiator support and front strut towers and some more trimming over the winter.
TransAm-Z
08-08-2012, 07:27 PM
These low weights make me sick! I just weighed in for the first time at 3950 car weight... That was with the Drag wheels, skinnies and only 1 seat.
Daily Driver w/some weight reduction, Full cage, sub-frame con, 9" ford, 4L80E, Iron block, 50lb 91mm turbo, air/water intercooler ect... Heavy Heavy Heavy!
I think I might be able to get it down to 3700-3800 fairly easy, but beyond that is gonna cost some serious $$
JL ws-6
08-08-2012, 08:29 PM
Lose the iron block, that's 100 lbs right there.. next time the motor's getting freshened up swap to an alum block... 4l80 is about the heaviest trans you can put in the car, so unless you really need the overdrive, I'd put a 2 speed in it and be done there, that will pull another 100 lbs out.
Alum center section for the rear end, that would save a good 40 plus. You have alot of weight you can get rid of easily if you're willing to do some parts swapping, etc. Cheap no, but there's plenty there.
I'm now looking ar 2800 with me in it, with an iron block bbc. Pic's in my rebuild thread, if you want to see what that will take.
Zero4488
08-08-2012, 09:14 PM
Well my car with the bolt ons and 9" with a Th400 and minor weight reduction weighed 3480 with me in it...took out a lot more but added a bar, turbo, and iron block...
