SS125
06-21-2012, 09:35 PM
I've run a fuel line from the fuel pump in the trunk under the car. I didn't want to run up beside the headers because they are going to be real close to the frame and real hot. So I ran the fuel line through a hole in front of the subframe connectors that went thru to the fenderwell. Here is a picture http://i1224.photobucket.com/albums/ee366/bestes125/f0b6a415.jpg. The other line you see coming down from the left comes down from the carb, is clamped to the motor plate, comes down to the kframe and will attach to that blue an fitting. Will this be okay, or will the tracks have a problem with the way its mounted.
Here is a pic of the line coming down thru the kframe. http://i1224.photobucket.com/albums/ee366/bestes125/dbaf9719.jpg
Here is a pic of the line coming down from the carb clamped to the motor plate. http://i1224.photobucket.com/albums/ee366/bestes125/ce5240ed.jpg
Here is a pic of where the fuel line runs from the regulator down behind the motor plate. http://i1224.photobucket.com/albums/ee366/bestes125/47ac827c.jpg
I guess my question is will this pass tech inspection?
