Mr Ed
06-22-2012, 11:12 AM
I am looking for suggestions on the sequence of things to try in order to diagnose the cause of a fuel pressure problem on my 1999 Z28.
The problem began very suddenly. I had just made three passes which had all been normal (11.7’s or so). Then, on the fourth pass I lost almost all power when I launched. Now, the car idles OK and drives at low speed OK but loses almost all power if I try to accelerate even just a little bit. It is not drivable on the highway and had to be towed home.
The fuel pressure with the motor off and with the key in on position is now 23 lbs. (s/b between 55 and 60). The pressure drops immediately to zero when the pump stops. At idle, I get a constant 23 lbs.
I should note that for the past two or three years the car has been driven only 4 or 5 times a year. So, I assume old fuel gumming up the works is a contributing factor.
