need help finding a few bolt spec's
Old 06-22-2012, 01:31 PM
devic's Avatar
Default need help finding a few bolt spec's
ive searched on here and google and can not seem to find the bolts i need
so was wondering if some 1 could help me out
my car is a 2000 transam auto
i need to know the specs of the following bolts
-torque converter bolts the 3 small ones that bolt to the flexplate
-transmission crossmember bolts
-transmission mount nut
-transmission bellhousing bolts
-ac pump bolts
it would be greatly appreciated if some 1 could help me out with this thank you
Old 06-22-2012, 02:21 PM
Undertow74's Avatar
Torque converter to flywhel bolts- 46 Ft/lbs
AC compressor pump bolt/bracket - 50Nm
Trans mount bolt - 38ft/lbs Trans nut 77 Ft/lbs
trans support bolt 66 ft/lbs
pulled those from alldatapro, i dont have my haynes manual at the moment
hope this helps
Old 06-22-2012, 02:56 PM
devic's Avatar
that does help but i was meaning the bolt sizes like how long and thread pitch and stuff
Old 06-23-2012, 09:00 PM
devic's Avatar
nobody knows these bolt sizes ?
Old 06-25-2012, 12:41 AM
devic's Avatar
well after several hours under my car trying to put the transmission back in with a hand full of bolts and washer i figured it out thanks thanks -_-
Old 06-25-2012, 02:15 AM
PREDATOR-Z's Avatar
www.ls1howto.com
Old 06-29-2012, 12:55 AM
devic's Avatar
thank u sir =]
Old 06-29-2012, 12:58 AM
devic's Avatar
still couldnt find them ? i only need the specs now on the ac bolts
