New LS1 Owners - Newbie Tech - can i just change for a 4" crank to make my ls2 into a 402?
caudo11
06-22-2012, 01:32 PM
I just wanted to know if I could just simply change my stock crank for 4" to make my LS2 into a 402?
I understand that getting a 402 stroker kit would be best but since my current engine is perfectly fine would it be a good idea to just switch? I'm trying to say save some money and any info would be extremely appreciated!
Sales4@Texas-Speed
06-22-2012, 02:58 PM
Unfortunately you can not do that. The stock pistons are not made for the 4" stroke crankshaft and will not setup correctly at all.
caudo11
06-22-2012, 03:06 PM
Damn, I was trying to say some cash but I guess there's no way... Thanks a lot for the info!
lebedin8654
06-22-2012, 03:39 PM
yea if you did that your pistons would it the heads! if you increase stroke you have to decrease the rod length or piston height
Sales4@Texas-Speed
06-22-2012, 04:58 PM
That is correct! Those pistons would have been sitting a good bit out of the hole on that one.
bww3588
06-23-2012, 04:42 AM
You need to lengthen the rods to clear the crank, and change the pistons to keep it where it should be in the bore.
vetteboy99
06-23-2012, 05:24 AM
You don't just simply swap your crank
caudo11
06-24-2012, 03:20 PM
This is why you ask in the forums... Is there another reason to? Anyways thanks for everyone's info
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
