General Maintenance & Repairs - a/c ??
View Full Version : a/c ??
jt_2002_ta
06-22-2012, 06:15 PM
my a/c has quit blowing through the vents in the dash and only comes out the floor vents. any ideas
t_raven
06-22-2012, 06:28 PM
The hvac doors are vacuum operated, you might just have a vacuum leak on the little plastic line that goes through the firewall, or the door actuator itself could be bad
LS6427
06-22-2012, 10:45 PM
See if the vacuum hose fell off the back of the intake...the port that is 1 inch below the map sensor on the back of the intake and that port points straight towards the passengers side. The hose is hard plastic and comes from the plastic black "T" valve over by the PCM.......
jt_2002_ta
06-23-2012, 06:26 AM
thanks for the suggestions,gonna check it out today. hope its a easy fix like that cause its getting f-ing hot!!!
FiredUpZ28
06-25-2012, 08:35 PM
Thats a good pic of the MAP area. I'd bet thats the problem.
