Generation IV External Engine - GEN 3 - GEN 4 Harness differences..
1Psycho
06-23-2012, 04:27 AM
There any differences in the harnesses themselves for the DBW motors to the DBC motors? I picked up a DBW 5.3 (assuming it's a gen 4) and have a drive by cable throttle body sitting around. Wondering if I put that on, will I have to change anything else in the harness and will my computer still work since it is programmed for a GEN 3 5.3???
Mike454SS
06-23-2012, 01:36 PM
A lot of Gen 3 engines are drive by wire, and all Gen 4 engines are drive by wire. You need to look at the cam and crank sensors to figure out if it's going to work or not. Gen 3 engines use 24 tooth crank wheels and 1 tooth cam sensors in the block at the back of the cam. Gen 4 engines use 58 tooth cranks and 4 tooth cam's, and the cam sensors are in the front in the timing cover.
SOME early Gen 4 engines use 24 tooth wheels, and you can run them with a Gen 3 computer, but that's LS2's, and I think it might only be LS2's, and not any 5.3's...but either way, a Gen 3 computer will not run a 58 tooth Gen 4 engine without a signal converter box from Lingenfelter.
1Psycho
06-23-2012, 08:48 PM
Completely forgot about the whole reluctor wheel thing lol..the cam sensor is on the back of the block where it is for a gen 3 motor so I take it that it's a gen 3
what would it take to make it a DBC? just the throttle body then?
pay attention to the cam, crank, maf, and injector connectors
Mike454SS
06-25-2012, 10:46 AM
Yes, if the cam sensor is in the back of the block (right on top behind the intake manifold) it's a Gen 3 engine. To make it DBC, you just need a compatible TB, and if the intake on it doesn't have the brass inserts to attach a cable bracket, you can rob them from another manifold and press them in too.
psiconversion
06-25-2012, 07:20 PM
You will need a RED/BLUE PCM to run the Drive By Cable as well. Some of the GREEN/BLUE PCMs have IAC drivers but it is easier/cheaper to find a RED/BLUE. Hope that helps.
JON
PSI
Mike454SS
06-28-2012, 04:43 PM
JON
PSI
Yeah, even if you run GTO code in a Green/Blue, it won't work unless it's got the drivers that a lot are missing.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
