Aluminum 5.3 block, how much are they?
The main question is do you want to save 80lbs?
An LS2 block if you aren't going to resleeve it allows for a wide valve selection (size) and has been low 8's with a stock crank, good rods/pistons, and quality thick deck aftermarket heads. (ie TFS/AFR/MAST etc)
5.3 bore is too small for a decent size intake valve to not be shrouded.
