Pontiac Firebird 1967-2002 - Quick headlight question for later today
Carguy8888
06-23-2012, 11:15 PM
I am changing the passenger high beam tomorow. I guess it needs to be done w/ the car running or the battery disconneted. I will choose the first option. I thought I saw cars with an extra notch on the switch to leave the doors up with the lights off. Duh. Any way here is my real question:
After installing the bulb and spring cleaning the other three I was thinking of lubricating the door housings. They work fine now. Should I do this & with what chemical? Thanks much. Brian.
alexus6798
06-23-2012, 11:17 PM
You can manually raise your lights up by turning the gear to the left to swap lamps. no answer for question..
Carguy8888
06-23-2012, 11:28 PM
Thanks, I don't want to turn screws b/c w/ my luck it will turn into a nightmare.
alexus6798
06-23-2012, 11:31 PM
You can turn the gear with your hand. I wish i had a picture to show what it was..
Carguy8888
06-23-2012, 11:36 PM
really, where is it?
alexus6798
06-23-2012, 11:38 PM
look right beside the lamp housing. It might have a rubber cap on it. pm me your number and i will run outside and snap a picture a text it to you.
Carguy8888
06-25-2012, 12:14 PM
Done, thanks for your help.
