Pontiac Firebird 1967-2002 - Should I get just in case & how many
Carguy8888
06-23-2012, 11:23 PM
In two weeks I am going to have my door pannel cracs fixed via the tie wrap method. Should I buy a couple of window stoppers just in case for the infamus door rattle? I am not doing it myself so I need to do it in one shot. Is there a way to check w/o the pannel off or should I buy 2?? Thank Brian.
Nathan C
06-25-2012, 11:08 AM
If you roll the window all the way down you can see if it is broken. I think they are discontinued from GM so if you can find a few extra window stoppers or guides you might want to get them just in case. I found mine on ebay for $15.
Carguy8888
06-25-2012, 11:41 AM
First,thank you for the reply. How can i tell. How much play should it have or can i see in the window track?
Nathan C
06-27-2012, 12:53 PM
There is usually a black felt pad that breaks or falls off. If you can't see the felt piece than the glass is rubbing against metal and that causes the rattle.
Carguy8888
06-27-2012, 02:58 PM
Forgot about that. Your the man. Any pics of your fleet?
Nathan C
06-29-2012, 02:41 PM
No, I don't have a digital camara. I actually have to go to the library to use the internet. No cell phone either!
phatasp
06-29-2012, 07:54 PM
What is the tie wrap method?
Carguy8888
07-01-2012, 01:40 PM
What is the tie wrap method?http://ls1tech.com/forums/appearance-detailing/1325462-how-fix-your-already-cracked-door-panels.html
Carguy8888
07-01-2012, 01:45 PM
I bet u have two nice cars always headed to the library.
What is a UMI SFC?
Nathan C
07-02-2012, 10:47 AM
UMI is the brand of subframe connectors I have. They are tubular bolt-ons and they help tighten up the suspension.
Carguy8888
07-02-2012, 11:19 AM
Got it, thanks partner.
