urgent help needed
Old 06-24-2012, 01:23 PM
orp0408's Avatar
Default urgent help needed
I have had my custom fesler 19x9.5 ordered for 9weeks now. The sales rep calls me on friday and says he's not sure if they will fit. I want to run 285/30/19 all the way around, and its 19x9.5 on all four corners. Am i going to be rubbing anywhere? the car is a 2002 trans am completely stock. Thanks for your time. (i have to call him on monday to confirm)
Old 06-24-2012, 01:55 PM
dforristall's Avatar
What is the offset on the rim? Barring it being a weird offset, I think you'll be ok. You may have to do a little BFH work on the inner fender well, but that should be it. I run 18X10.5 in all the way around with 295/35R18 tires on all four corners. I have Z06 replicas with a 56mm offset, but I run a 15mm spacer to make my effective offset 41mm.
Old 06-24-2012, 03:23 PM
carlos64030's Avatar
If the wheels are being built to an offset of your choice, go with a 38mm offset.
Old 06-25-2012, 05:24 AM
orp0408's Avatar
thanks everyone!
