Drag Racing Tech - High compression SBE experiment
View Full Version : High compression SBE experiment
Grr
06-24-2012, 10:43 PM
Thought I would post up my build for some of you to check out. First off, I dont care if you think im an idiot for doing it, I dont give a shit if you think it wont work, so dont bother with the negative comments
Anyway I wanted to build a motor that I had been kickin around in my head for quite awhile, and if it didnt work I had no one to blame but myself. I did run it for a bit today and took it up to 6800 a few times and havent had any problems, but I know its fucking tight in there!
I had to pull the trans and had a light weep from the pass side headgasket, had most of the parts laying around so I went for it.
Removed the drivetrain
http://i214.photobucket.com/albums/cc192/Grrh77/2000%20Z28/CAM00047.jpg
Pulled the heads
http://i214.photobucket.com/albums/cc192/Grrh77/2000%20Z28/CAM00049.jpg
Then I stopped taking pics, phone went dead!
:pics:
Flycut the pistons as far as I dared, about 0.130 intake and exhaust
Heads are ported 243s that have been MILLED :eek2: .125 or so
224cc intake
78.5cc exhaust
46.75cc chambers
Brian Tooley platinum dual springs with Titanium retainers
Ferrea 6000 series valves
GM .051" MLS gasket
stock rockers with Comp trunion upgrade
7.300" pushrods with .042 preload
Ebay headstuds (awesome BTW)
http://i214.photobucket.com/albums/cc192/Grrh77/CAM00037.jpg
http://i214.photobucket.com/albums/cc192/Grrh77/2000%20Z28/CAM00036.jpg
Cam is a EPS 236/248 .615" on a 111+3 installed straight up. Piston to valve is tight as shit, I came in at about .035-.040 on the intake and .040-.050 on the exhaust.
Finished it up today and it works! compression is right about 13:1 and Im running E85 and have to use the LS1 intake till winter when it will get a vic jr and 4150 throttle body. Car also has BBK 1 3/4 headers and Borla adjustable catback. 104mm lid ported throttle body and 1-bar SD.
I just got it running and have to pull the trans again but will be putting up a vid shortly and hope to have it done again this weekend. Also will be checking cranking compression which will be pretty high my small battery has a struggle to turn it over now. Will keep this thread updated! feel free to ask questions
Gary
saluki
06-24-2012, 10:48 PM
sounds great.
Most of your pics aren't working here though
Grr
06-25-2012, 10:35 PM
http://youtu.be/kgPimwzuuaI
Little vid I took today if it shows up
~Gary
Mighty Whitey
06-27-2012, 04:05 PM
I like your style! I'm hoping to get in to an 11.8-12:1 stock short block setup over the winter, I only wish I could get 13:1!
chrs1313
07-02-2012, 03:58 PM
Let see what she ends up doing... :)
Have only pushed around 12.4:1 here with .120 cuts...
Made 525rwhp with my setup and 497rwhp with 12.4:1 243 headed setup...
Grr
07-02-2012, 06:00 PM
thanks chris, the car runs great, drove it around all weekend in 100* high humidity with the AC blasting the whole time, Im on my 3rd tank of E85 with the new setup already. Its going to really leave alot on the table until I get the intake changed but the tq from 3500-5000 is simply crazy. I forgot to post up some vids I took in this thread, still working on getting it tuned in some but its close enough to drive around for now, gotta order a new wideband. Cant run more than 22-23* timing in this heat, IATs are 120+ most of the time
http://youtu.be/SyqyIUsYSgg
http://youtu.be/HJJ1ElkEjiE
http://youtu.be/7g94_1FIFqg
Fbodyjunkie06
07-05-2012, 12:08 AM
Love it, should really run good with the Vic Jr.
Grr
09-22-2012, 11:00 PM
Finally got to the track with my new tires
stock bottom end
EPS cam 238/246 .607/.609 111+3
243s ported by me, milled to 46.8cc (.135" or so)
PTC 10"LS1 1.8 STR, 3800 stall
stock trans
10-bolt with 4.10s (a little louder after 5 1.6x 60's)
all suspension is stock except for ST lowering springs and relocation brackets
Darkstars with 295/65-15 mickeys
Still running the stock LS1 intake manifold, which is KILLING it. Just dead above 5500, man I need to put a victor on it
1.62
7.28@95
11.41@120
I think with a single plane and TB, and a set of 1 7/8 headers it would trap 125-128 and go 10's pretty easy. this intake has to be hurting me 30whp at least
studderin
09-23-2012, 02:46 PM
sounds like your having fun. stock sized valves? you running the heads like the pic of the stock chamber
fergymoto
09-23-2012, 02:56 PM
stock bottom end
stock trans
1.62
7.28@95
11.41@120
The intake probably doesn't even fit anymore milling 1/8" off the heads. That's a freaking ton. The port alignment has to be off. If that was a SBC/BBC intake it wouldn't of come close to bolting back on without a lot of work. I'd check into the port alignment and see where it's at.
Grr
09-23-2012, 07:00 PM
Stock size valves, I smoothed the chambers and blended them in after I took that pic, that pic is at 46cc
The intake fits just fine, I milled it accordingly to get it to match up
studderin
09-23-2012, 07:11 PM
you should have checked the weight of those values over the stocks. you have 10 maybe 20hp in a better VJ, and blending for what you have like that. even with that valve and that ported runner
Grr
09-23-2012, 07:55 PM
got the valves with the heads or I would have done LS3 valves. I would not have bought them but im not gonna throw em out
There was ALOT more work done on the heads after that pic was taken, that is just the last one I had
IllusionalTA
09-24-2012, 02:17 PM
I think you'd a genius.. I have a similar setup only diff is, non ported 317's milled. .100 and I'm already running s single plane on a lQ9.. Haven't gotten to track yet but made 450rw through a 400 on pump gas and 26* I expect it to run well.. As yours will.. Think outside the box it's the way to go... Nice job!!!
djfury05
09-24-2012, 02:56 PM
pretty cool.. hurry up and get the victor on there!
Grr
09-24-2012, 03:13 PM
Illusional:
yeah I saw your build on the bullet (i think) and i was like "hey thats pretty similar to mine" That super and 4500 must be working to get that through a stock 317 runner
Funny last night my buddy said after I left the track everybody was
"BULLSHIT GARY'S GOT NITROUS!!"
I just had to laugh at that, we have some pretty serious LSx stuff up here lately so its getting fun, not uncommon to see 2 turbo LSx cars side by side a couple times a day it seems, hell I think thats 25% of the people at the track now
On another note, Im very torn on throwing the turbo I have on this and seeing if the heads will stay down on 10#. See how the winter goes Im done for the year gotta work the next month straight then its gonna snow!
IllusionalTA
09-24-2012, 03:38 PM
Yea not sure how it works , gonna change my springs , and tune it on e98 with a lil timing. And let her eat.. :)
98blueSScamaro
09-24-2012, 04:08 PM
valve job's work wonders. just did my heads cant wait to see what it gains
IllusionalTA
09-24-2012, 04:28 PM
Kickin around the same idea, over winter. With some lighter valves..
98blueSScamaro
09-24-2012, 04:57 PM
Did that as well rev T.I valves holly shit i just turned 2k ETP 215 heads into 4k heads that was not smart lol.:cheers: and high rpm here i come on 12.4.1 stock pistons and rod bolts. :drive:
98blueSScamaro
09-24-2012, 05:01 PM
post #3 is my old setup new ETP 215 heads milled to 54 cc T.I valve's went from 115 grams to 70ish and 50deg valve job and 55 deg valve job
http://ls1tech.com/forums/dynamometer-results-comparisons/1541760-top-10-rwhp-per-cubic-inch-na.html
Grr
09-24-2012, 09:15 PM
you might get a kick out of this:
I lose so much power over 5500 that I had to shift at
wait for it.....
6100. It goes slower anywhere else. sooooo this cam has a powerband of 4500-7500, and I peak hp around 5600 with the LS1 intake, think there is a little more in it??
I want to shift around 7100 when I get the intake on it
98blueSScamaro
09-24-2012, 10:40 PM
I shifted mine as high as 7300 but I went slower. Mine liked 6800 it's a matter of shift timing and how far the rpm falls on shifts to really find the sweet spot
