Drag Racing Tech - when to spray
View Full Version : when to spray
daniel(sleepysleepy)
06-25-2012, 05:02 AM
ls1 dyno tuned
over sized fuel pump
slp intake lid
cut exhaust
after market pan. and torquesion bar or somethin like that
automatic stock gears and internals
100 shot Nitrous single nozel wet
hp on motor 330 torque 440
hp on spray 440 torque 480
10.5 street tires parellies
so when do Yall suggest I spray in the.1/4 and 1/8
Posted from LS1Tech.com App for Android
lemons12
06-25-2012, 05:10 AM
Immediately...
06-25-2012, 05:20 AM
should I not worry about just spinning ur killing my engine?
06-25-2012, 05:21 AM
its still a daily driver so I can't afford for it to go down
lemons12
06-25-2012, 05:28 AM
Gotta pay to play... I missed the street tires... Street tires will never hold a shot out of the hole. Get a real tire under it or don't spray. I wouldn't spray half way down the track, kinda pointless at that stage IMO.
06-25-2012, 05:30 AM
or spray and deal with the spin with the rear suspension upgrade it has no wheel hop and holds straight unlike most street cars
SuperSlow02
06-25-2012, 08:45 AM
Most likely wouldnt hook up till around 50mph.... And if your worried about breaking it, don't race it
06-25-2012, 09:22 AM
the way I look at it its gonna break either on the strip or on the street its not if its when I'm just trying to keep it going for as long as I can
TransAmcoupe98
06-25-2012, 10:01 AM
this...
BlackScreaminMachine
06-25-2012, 10:39 AM
Then don't race your car.
06-25-2012, 11:40 AM
either way its getting raced to fun not to I just plan on biting the bullet when somethin happens
BLK95-Z
06-25-2012, 11:51 AM
ls1 dyno tuned
slp intake lid
cut exhaust
Thats alot of torque
06-25-2012, 12:10 PM
meant 340 on motor I'm on a.cell phone doin this so I have issues with hitting the wrong button
06-25-2012, 01:04 PM
50-75 hp setting on a WOT switch.
Probably the safest you can do all things considered.
06-25-2012, 01:31 PM
ok thanks man
djsanchez2
06-25-2012, 08:46 PM
How about a progressive unit? You could simply ramp up a 100-125 shot. It would be easy on the tires and give you a killer mph in the top end.
06-25-2012, 08:50 PM
I been looking into those right now I'm just using a throttle switch and arming it right after I get traction
djsanchez2
06-25-2012, 09:20 PM
They make a really affordable mini controller. Just an option to get you going safely.
06-25-2012, 10:16 PM
I'm gonna eventually get one but my car is really just to say I can cruise but still put good numbers up cause it never fails while I'm sitting in the parking lot enjoying a beer someone calls me out I'm not big in racing just like to prove a point
dannyz
06-25-2012, 10:43 PM
OK. From the beginning...
Tell me you are not still on stock plugs?
Did your tune add timing to what it came with stock?
You DON"T have a window switch. So if you spin badly enough on juice, you could hit the rev limiter, which could be a real bummer. In addition to wheel spin, breaking a u-joint
or the 10 bolt rear would also result in pegging the rev limiter. Again, a real bummer.
For now, like was suggested above, jet down to maybe a 50 shot.
It is still quite a bit of improvement and a lot less risky.
Also, and I am just guessing, looking at your tq, I am thinking you are running pretty rich.
06-25-2012, 11:27 PM
plugs have been changed along with timing also a colder thermostat and larger fuel pump to accommodate the Nitrous
06-25-2012, 11:28 PM
yes I run very rich
Orange99Z
06-26-2012, 03:02 AM
...while I'm sitting in the parking lot enjoying a beer someone calls me out I'm not big in racing just like to prove a point
Dumb.
I sprayed a 200 shot through a stock engine with a window switch, timing twister, & NGK TR6 plugs. Keep the juice low like they said unless you change your timing for a bigger shot. Don't spray into the rev limiter. I sprayed between 3000 & 6600 rpm with a 6800 rev limiter. It was also on a wot switch.
lemons12
06-26-2012, 03:05 AM
Drinking and cars. Never, those don't go together.
Drinking.
Cars.
Go perfectly together.
