General Maintenance & Repairs - time for motor mounts, anything else?
dc4bill
06-25-2012, 09:56 AM
so i made the mistake of doing LT's without doing motor mounts while they were out, my question now is
while i'm doing the mounts,is there any other things that would be easier to knock out while im at it? let me know from your experiences please!
mjs1012
06-25-2012, 11:11 AM
Make sure you pit the motor mounts with the tabs facing up and take your time and have fun.
dc4bill
06-27-2012, 08:13 AM
i'll keep it in mind, thank you
00 T/A Ron Burgondy
06-27-2012, 11:46 AM
Made the same mistake this spring. However, it's going to have to wait until fall to replace mine. Let me know how much of a PITA it is!
mjs1012
06-27-2012, 02:39 PM
to be honest i had to do one of mine (pass side) with the header in because i had my mount the wrong way and it wasnt bad at all. there was plenty of room to get tools in there.
Op to make thing easier loosen the 4 15mm bolts on the base of pedestal so you can move the mount and tweak as necessary.
mike171562
06-27-2012, 03:49 PM
I wish I had done my oil pan gasket when I was doing my mounts, they were such a bitch to get in and it was so hot, i just wanted to get it all back together
dc4bill
07-16-2012, 02:07 PM
hmm might knock that out while i do it too, looks like its leaking a lil bit
Zlow28
07-16-2012, 02:10 PM
did you do plugs/wires when you did headers last time? If not, now might be a good time.
LS1121
07-16-2012, 03:42 PM
Check your Tranny mount while your down there. I did Poly MM and a rubber tranny mount, seems like the best combination.
