cam choice ahhhh
Old 06-25-2012, 04:20 PM
GMtechmatt's Avatar
Default cam choice ahhhh
what a tuff choice between TSP. thunder and venegence racing asking for all inputs. cam with good drivabilty and performance and power.
Old 06-25-2012, 04:27 PM
GMtechmatt's Avatar
looking to make 400+whp with stock ported heads and .650 patriot valvesprings
Old 06-26-2012, 03:07 PM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
What size torque converter do you have? I assume this is for the car in your sig.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 06-26-2012, 03:39 PM
hotrodth's Avatar
If you're interested I have a tsp 233/239 with only 200 miles on it. Only reason I want to sell is due to ptv clearance w new heads. Stock heads are fine. Lmk if interested.
Old 06-27-2012, 11:26 AM
superGTO's Avatar
I know some guys are making pretty good power with the stock LS7 and LS9 cams on stock without having to spend 400 on a custom grind. But I don't know about 400.
Old 06-27-2012, 12:50 PM
PREDATOR-Z's Avatar
IIRC LS7 and LS9 cams will not fit Gen 1 LS1.
Old 07-16-2012, 04:16 PM
GMtechmatt's Avatar
there is a 2800 in it now
Old 07-16-2012, 04:43 PM
mark21742's Avatar
I'd jump up to a 4,000 stall first, before you go with a bigger cam.
Old 07-16-2012, 08:58 PM
Z28-Z71mAn's Avatar
How much are you asking for the cam? Whats the lsa on it?
Old 07-16-2012, 11:19 PM
TransAmcoupe98's Avatar
Converter is way to small IMO. I would also get a 4000. A 228/232 is a freakin awesome daily driver cam.
Old 07-16-2012, 11:52 PM
OP, we can get you set up with a camshaft that will match that converter. Are you looking to keep that converter, or are you interested in going with a higher stall speed? Did you already have a camshaft in mind?
__________________
Old 07-17-2012, 07:33 AM
Ethan[ws6]'s Avatar
What? Why 4000? You don't even know anything about the car? Why would you spec that high of a stall speed lmao
OP, TSP is good ****. Call them up and they will solve all your problems
Old 07-17-2012, 09:22 AM
Captain Double Post
BOBS99SS's Avatar
Big fan of tsp, they have always been great to me, and if i ever got stuck on a install or question they always helped me out ,
Old 07-17-2012, 09:27 AM
2QUIK4U's Avatar
I have had cams from all 3 of those vendors. I think for your particular application with a very mild converter the TSP 228r or the vengeance VRX3 would be a good choice. I would not recommend Thunder Racing at this point. There customer service has gotten terrible. I ordered a cam from them at the end of last year and after 2 months of getting the run around I had to cancel my order. I ended up getting a cam from Vengeance.
Old 07-17-2012, 09:53 AM
PREDATOR-Z's Avatar
Please let us not turn this into another TSP nut swinging thread.
Old 07-17-2012, 11:54 AM
SSRed2k2's Avatar
See this thread. https://ls1tech.com/forums/generatio...ls-inside.html
My car made 391RWHP with 341 heads, and excellent street manners.
D
Old 07-17-2012, 03:21 PM
mark21742's Avatar
A 4,000 stall is not "that" big....if he is looking for a bigger cam, then it only makes sense to go with a higher stall first....unless he wants a car with a prayer cam that performs like a dog, will not want to idle, and push through the brakes....trust me I know what I am talking about.
Old 07-17-2012, 04:20 PM
Sladester2's Avatar
tsp 228r. hands down. matches what you asked for.
Old 07-17-2012, 04:36 PM
njmaster's Avatar
228R here. If you go with something like the 228R you don't necessarily have to go with something stalled quite so high. You could do 3200. I went with Yanks 3600ss, but that's just me. ha
Old 07-17-2012, 04:53 PM
jrmchevyman's Avatar
I'm with the others, the tsp228r is a good choice. I would get a 9.5" or 10" 3400rpm torque converter from one of the sponsors. CircleD, FTI, etc..
A 3200rpm would be okay if it was a smaller diameter such as a 9.5 or 10" converter. I'd try to get a 3400-3600 imo though.
Quick Reply: cam choice ahhhh
