** 225/225 Duration 581/581 Lift on 113+1 LSA CAM **
Category: Engine - Power Adders
Price: $230
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): FL
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
FROM COMP:
SERIAL # J 1311-06 SPEC CARD # 10992306 SPEC CARD INQUIRY BY SERIAL #
PART # 54-000-11 CAMSHAFT, LS1 CHEVY LS1/GEN III '97-UP
CORE C54-11AA CAMSHAFT BLANK, LS1 1997 UP 5.7 CORVETTE Special Grind
GRIND # LS1 3722R /3722R HR113 +1
DURATION @ .050 INTAKE 225 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 225 INTAKE 1.70
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3420 EXHAUST 1.70
VALVE LIFT INTAKE .581 LOBE LIFT EXHAUST .3420
VALVE LIFT EXHAUST .581 LOBE SEPARATION 113.0
DURATION .006 INTAKE C/L 112.0
TAPPET LIFT INTAKE 273 CAM ADVANCE 1
TAPPET LIFT EXHAUST 273 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 0 JOURNAL DIAMETER STD 2.165
VALVE OPEN EXHAUST 46 RECOMMEND VALVE SPRINGS
VALVE CLOSED INTAKE 44 DEPARTMENT P
VALVE CLOSED EXHAUST 2- SPC INSTR FOR CUSTOMER
LS1Tech Premium Sponsor
Hey Jeff it is Kyle that used to work over at Precision, I will take this cam off your hands.
Thanks,
Kyle
Thanks,
Kyle
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
