Paint & Body Work - What kind of welder to buy to weld body panels ?
mrrman
06-25-2012, 07:50 PM
I talked with a friend about getting some body panels welded on my car, 67 Firebird. He has a welder but it cant do this type of job. Instead of hiring someone to do this I mentioned that I will buy the welder and he can do the work. What kind of welder do I buy to weld body panels? I saw this at Harbor Freight, is this good enough?
http://www.harborfreight.com/170-Amp-MIGFlux-Wire-Welder-68885.html?ccdenc=eyJjb2RlIjoiNjc4NjgzMjIiLCJza3Ui OiI2ODg4NSIsImlzIjoiMTc5Ljk5IiwicHJvZHVjdF9p%0D%0A ZCI6Ijg1NzQifQ%3D%3D%0D%0A&utm_medium=email&utm_campaign=2612a&utm_source=1003
Jr.Samples
06-25-2012, 09:00 PM
Sure but I would plan and practice before atempting.
jlcustomz
06-25-2012, 10:29 PM
Welding with flux core wire is much messier than uncoated wire & 75/25 mix shielding gas. I might use something that cheap to weld trailer brackets, but not automotive panels.Not sure if the harbor freight models are convertable to gas.Lincolns like sold at homestores aren,t bad, Hobart is just underneath miller in price& features.
BODYSHOPGOAT
07-05-2012, 06:15 PM
just get a snap on, miller, lincoln, mig for 1000 - 1300 works great for sheetmetal and still works with some thicker.
TyCZ28
07-05-2012, 06:31 PM
got my 125 flux from northern tool for 200 bucks... Flux works just as good as regular
GMAW do such as your typical MIG.. you just gotta remember than FLUX usually welds hotter and you have more cleanup between welds... flux is more common on ranches because you dont have to have perfectly clean surfaces to weld...
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
