Run/Crank and Power/Train Relay Size ?
I am building my own fuse block for my l92 engine installation. Right now the relays I have on hand are 50amps each. Will 50 amps be enough to handle the Run/Crank? Will 50 amps be enough to handle the Power/Train relay? I am using a modified factory harness.
That is good news. Thank You for the reply. I might add for discuission that the N/O side is 50amps and the N/C side is less something like 30 amps. I will be using the N/O side.
