SilverSS07
06-26-2012, 12:29 PM
Well with all this rain from the tropical storm the TA started leaking water into the hatch area. I never had a problem with it until after it got painted. I sucked up a little over 3 gallons from between the t top holders today. I've searched as many threads as I could find about it leaking but never saw this mentioned. The water seems to be coming in from just above the taillights where the water drains run down the side of the hatch. There's these little plastic things that don't lay flat and it seems the water runs under them and into the trunk area. Are these supposed to lay flat? Should I put some RTV under them?http://img401.imageshack.us/img401/7892/002das.jpg
This is from the driver side corner. It looks like it runs down both the driver and pass side. Is this a common thing? I couldn't find anything about it.
http://img201.imageshack.us/img201/6541/001pey.jpg
