SSmokin99
06-26-2012, 03:04 PM
On April 14th I swapped out my Pacesetter LT's and LS6 intake (EGR). I put in brand new QTP LT headers and my LS6 intake from my 02 Z28. I got rid of the AIR/EGR on my car and during this install I broke the wire that plugs in to the alternator. I rewired it and soldered the wire together. Well, this is where my problems started!
I fired up my car and drove it around for a while, but I noticed my temperature gauge wasn't working. I checked the sensor on the drivers side head and checked the connection. Everything appeared to be fine, but problems still occurred. Keep in mind that this sensor was 1.5 months old prior to doing this swap and it worked perfectly fine AND I replaced this sensor again a few weeks after this install. That makes it 2 new sensors, but still the same problems. So the next day I drove it around and the temperature gauge started to work again.
After my car is warm and driving a bit my temperature gauge will fluctuate erratically and while this happens my car starts to bog really bad and sometimes when this happens my temperature gauge will go all the way to 0 and the car stops bogging. Sometimes the gauge even goes past normal operating temps. I have no idea what it could be and I even took it to Nick at Newtech to check my tune, but everything was good. He said deleting my AIR/EGR wouldn't cause these problems.
I kinda think that MAYBE it's my alarm and the wiring, but I've had my Viper alarm installed last summer so why would these malfunctions happen now? I checked the grounds for the alternator and starter, but still can't figure out the problem.
So, yesterday I decide to start my car since it has been sitting for about 3 weeks. My car was dead and while trying to fire it up it just clicked repeatedly. I installed a new alternator yesterday and today, same problem. My battery was purchased in March too so I doubt that could be my starting problem. Do you think it could be my starter? When trying to start my car my security light comes on and it won't turn over at all unless my security light turns off. So I basically have 2 major problems that's really annoying me.
My friend said my coolant temperature gauge problem could be due to having air bubbles in my coolant system. I was going to bleed it today, but my car wouldn't start so I was pissed and just left it alone. What are my options here? What would you guys do? So I take it to Synergy to see if they can find the culprit? My last option for the temperature gauge is to bleed the system, but if that doesn't work then I don't know...
