ChairForceRacer
06-26-2012, 03:15 PM
Its a 06 Pontiac GTO, 6 Speed Manual, red, 80000 miles and still drivin. It has many performance parts listed below. It will come with almost all the stock parts if wanted. The car made 440WHP and 405WTQ, It was Tuned by Kris Keltner in Little Rock, AR. Car has Legal tint all around.
Motor:
SNL Performance V.X. Camshaft 23X/24X 64X/63X 112+2 (Exact specs are kept a secert)
Patriot Performcance Extreme Dual Spring Valve Springs
ARP Head Studs
LS7 Lifters
New GM Head Gasket 5k miles ago(done with cam swap)
Meling High Volume Oil Pump
ARP Cam Bolts
Elite Engeering Catch can
Comp Cams 5/16" Hi-Tech Chromeoly pushrods
Kooks 1 7/8" Longtube headers coated
Kooks 3" catless midpipes
Spintech X-Pipe w/ Dynomax Bullets dumped before the axle
ASP Underdrive Pulley
Ported Intake Manifold
Ported Throttle Body
Fast 57lb Injectors
Lingenfelter Fuel Pump
DriveTrain:
Monster Stage 3 Clutch w/18lb Flywheel
Tick Performance Stage 2 T56
Tick Performance Adjustable Master Cylinder
Detroit TruTrac Differential
Aussie 3.91 Rear n Pinion Gears
GMM Short Shifter
Suspension/Brakes:
Peddlers 5/16" Raise Rear Springs
Peddlers Front Sway Bar Link Bushings
Front Drilled Rotors
Rear Drilled Rotors
Interior:
NGK Wideband
HP Tuners Pro
Exterior:
Black Powercoated Stock 17" Rims
2 Extra Stock Black Powder Coated 17" Rims w/ 245/45-17" Nitto 555r's with half life left
The Bad:
Dent in passenger fender (will be fixed before sale)
Clear coat pealing on gas cap cover (will be fixed before sale)
Clear coat pealing on licence plate panel (will be fixed before sale)
Small dent on hood (might have fixed before sale)
The normal light scratches from a 80000 mile car
If Interested Call Mike at (813) 260-0909. Serious Buyers Only. NO TRADES! Car KBB for $15000 and I have over $10000 in Upgrades.
Motor:
ARP Head Studs
LS7 Lifters
ARP Cam Bolts
Fast 57lb Injectors
DriveTrain:
GMM Short Shifter
Suspension/Brakes:
Rear Drilled Rotors
Interior:
NGK Wideband
HP Tuners Pro
Exterior:
The Bad:
