lt1 turbo 400 guys step in N/A only
I see hvyss hasn't responded, but he's running a TH400 (2.48 low gear), PTC3800 converter (picked for nitrous), and a small 22x/23x HR (similar numbers to your XFI280) in his 385. That car has gone a best NA of 11.01 @ 121. It's an ImpalaSS, so a lot heavier than what you're probably looking at.
Are you stock cubes, or stroker?
OP- are you dead set on running a th400? Why not a th350?
Most guys typically shave .4-.6 off of their initial passes with simple tweaks over the next few months. so his 11.2's would probably end up becoming 10.6-10.8's after he messes with the tune, changes plugs, changes tire pressure, launch rpm, oil level, adjusts the suspension, etc. 3000ft da is not very good air to be running in. If he were to run in some good air in the fall, he'd be in the 10's as it sits.
