Fueling & Injection - Is there an in-tank pump for 1200hp E85?
pwrtrip75
06-27-2012, 06:59 AM
My dual walbros need an upgrade. I've got everything wired and plumbed for an in-tank setup, -10 lines.. what are some options for in-tank pumps that would do this? ....And not be maxed out. Is there 1 big pump? 2 other better pumps?
99 Transam. Factory tank.
LS1NOVA
06-27-2012, 07:15 AM
1200 flywheel? E85 or not? The Magnafuel 4303 can be submerged and would do it on reg gas or E. I cant tell you if it will fit in the stock tank though. You could do twin Bosch 044's if you can get them in there also.
pwrtrip75
06-27-2012, 07:22 AM
As the title said E85... yes. :) 1200 flywheel... but I dont want the pump maxed out at that. So 1500 hp flywheel maybe. I considered the 044's but was curious if there was one pump that would do the job.....reliably, and fit in the tank.
Mr. Fuel Pump
06-27-2012, 09:20 PM
http://www.racetronix.biz/itemdesc.asp?ic=F90000267&eq=&Tp=
Two of the Walbro F90000267's are your best option for flow and E85 for intank...but 1500hp support is questionable
pwrtrip75
06-28-2012, 06:02 AM
I cannot find the price on that pump on that page. ?? I guess they dont want to sell them....Good thing there is Ebay. Are they better than the Bosch 044's?... Or the aeromotive in tank stealth ones?
Mr. Fuel Pump
06-29-2012, 04:26 PM
The f90000267 flows more than both and is truly e85 compatible, so yes it is better in my opinion for your situation
Slowhawk
07-02-2012, 08:01 AM
2 44's will not do it. You need a sumped setup with probly 2 4303's
LS1NOVA
07-02-2012, 09:49 AM
Ive got a car running right around 1200 flywheel on one 4303 right now.
