New LS1 Owners - Newbie Tech - short throw shifter
beastlyredz28
06-27-2012, 01:21 PM
i have a mgw short throw shifter but i want a shorter shifter rod. anyone have any suggestions on where i can buy a shorter rod?
TyCZ28
06-27-2012, 01:40 PM
http://www.ws6project.com/user_stor/catalog/ws6store-t56-short-stick-1/
There ya go!
I have the short stick from ws6store. I'm very pleased.
2win_SS
06-27-2012, 03:50 PM
I dnt think you can use the ShortStick on the MGW... just cut and re-thread your existing stick. Done
udienow
06-28-2012, 09:18 AM
Yeah I dont think that works on the MGW. I did a lot of research on the MGW in the past as I have been looking to get one myself, and I think your only option is to cut the actual stick and re-thread it.
2win_SS
06-28-2012, 09:29 AM
^^^ Thats all there is to do. If u want a shifter you can swap sticks. Get a hurst or pro5.0, B&M MGW can't change Sticks
bwilde86
06-29-2012, 08:02 PM
How would you rethread it?
My6speedZ
06-29-2012, 08:10 PM
Any machine shop could do it.
BackNBlue
06-29-2012, 09:05 PM
If you have a newer MGW that's not stepped you can just cut the end off that goes in the shifter. No retreading needed. If you have the old style rod you might just get a new one from them?
2win_SS
06-30-2012, 07:19 PM
True cut the bottom of stick. Dnt need to thread
94zGreen
07-02-2012, 08:41 PM
I think I have the new style, there is a little notch about an inch and a half from the bottom that has a groove around it, and the instructions say to cut it there if you want it shorter. Hope that helps!
xxKennyDxx
07-03-2012, 09:27 PM
I thought the MGW was a little shorter than the stock shift stick?
I just ordered mine last night. I don't mind how the Hurst I have sits now, is there a height difference from the two?
My6speedZ
07-03-2012, 09:31 PM
with the Hurst knob no not much might even be a bit shorter. When your using a different knob like a Hurts ball knob that is threaded as deep it will sit kind of high.
xxKennyDxx
07-03-2012, 10:26 PM
Ah, what did you end up using as your knob?
I don't mind how it sits stock to be honest. But looking at the WS6Store..man that looks right!
trans damm
07-03-2012, 10:48 PM
I notice when ordering mgw shifter there are two options for thread. One is stock and the other is a different thread/pitch. What are you guys ordering. Btw sorry to butt in on your thread but didn't want to start a new one for a simple explanation.
My6speedZ
07-03-2012, 11:18 PM
I started with the Cue Ball knob but I didn't like it and gave it to my dad to use. Now I am running the factory H leather knob
I order it with the stock threads.
trans damm
07-03-2012, 11:36 PM
That was my plan. Thanks.
