Cadillac CTS-V - Nylon Shifter Cup available seperately?
9t8z28
06-27-2012, 01:33 PM
I am going to be purchasing a Katech Shifter but my stock shifter cup is worn out. Does anyone know of a source for this part or have one that they are willing to part with? GM part# ?
Here is a pic of the nylon cup. It is (2) pieces.
http://i118.photobucket.com/albums/o89/9t8z28/CTS-VSHIFTERNYLONCUP-1.jpg
etcts-v
06-27-2012, 07:25 PM
I would go this route:
https://creative-steel.com/store/index.php?l=product_detail&p=37
4doortypels
06-27-2012, 07:44 PM
^ he is talking about the nylon cup that goes around the shifter ball, not the bushings... i too am curious as well, as im interested in replacing mine as well
VeryWhiteDevil
06-27-2012, 07:56 PM
there is a vendor out there with brass inserts. I think you can google it. otherwise, no other choices.
I was able to purchase a set of poly ones from a member that had two sets made.
9t8z28
06-27-2012, 08:11 PM
You are both looking at the wrong part. Look further up the shaft just directly above the rubber boot. There is a nylon ball on the shaft of the shifter that rotates in the 2 piece nylon cup.
etcts-v
06-27-2012, 09:01 PM
It's not sold individually by GM, the shifter is one piece. Maybe a used shifter on E-bay possibly? Haven't heard of another source, if you find one I'd be interested myself!
Shifter - 25746745 - $300 online
Plate - 10384405 - $250 online
http://i949.photobucket.com/albums/ad335/ellioth3771/0810106D04-029.jpg
07CTS-V
06-28-2012, 04:56 AM
I might have one or two sets sitting around from people sending them to me with their stock shifters. PM me and I'll check
STAGEUP
06-28-2012, 08:15 AM
I made my own out of a block of poly. Worked perfect!
punishmentcycle
06-28-2012, 09:41 AM
im in the hunt for one as well... STAGEUP..if ur willing to make me one ill pay u for ur time and materials..please let me know
9t8z28
06-28-2012, 09:50 AM
Polyurethane? Details? Pics?
FuzzyLog1c
04-15-2013, 07:55 PM
I want to bring this thread back and ask whether Brian or Stageup have anything available on the shifter cup front.
runsfromdacops
04-15-2013, 08:20 PM
Id be on baord for one also if yhey areaking them
FuzzyLog1c
04-15-2013, 08:41 PM
You okay there? :eyes:
NIKDSC5
04-15-2013, 10:10 PM
Haha clsssic fat fingered phone post. Love it.
07CTS-V
04-15-2013, 10:27 PM
I have an extra set. I'll bring them to my die shop this week and see how much to have some replacements made. I have never seen the outer housing wear out though. Usually I see the ball wear out first. I will be sourcing some of them also.
To be honest, I've been thinking about designing an entirely new nylon and metal cup assembly to raise the shifter into the console without any further modifications. This will raise the bottom of the aftermarket short shifters and keep them from hitting the top of the trans and driveshaft couplers.
FuzzyLog1c
04-15-2013, 11:37 PM
Well, if you have an extra, I'll buy it from you.
DougNuts
04-16-2013, 07:45 AM
I'm in for a set of whatever you come up with.
Onefast V
04-16-2013, 08:45 AM
Also interested
9t8z28
04-16-2013, 09:24 AM
I received a new nylon 2 piece shell from 07CTS-V. When I installed it in the steel cup and bolted it down the shifter still had some play. I discovered that the 2 piece shell moves around side to side and up and down. I tried putting a spacer under the shell, this helped a little. I was thinking of taking it apart again and using a two part epoxy glue to fill the voids. Anyone else consider this?
