Generation IV External Engine - DBC throttle body LS2 ?
cartel
06-28-2012, 01:00 AM
is there a reasonably priced TB thats wire-- and bolts on to LS2 intake?
or do i need the LS2 to LS1 adapters and then a LS1 type TB?
like this adapter
http://www.ebay.com/itm/290658902587?_trksid=p3984.m1438.l2649&item=290658902587&viewitem=&sspagename=STRK:MEWAX:IT&vxp=mtr
psiconversion
06-28-2012, 07:42 AM
Do you mean cable?
Jon
PSI
cartel
06-28-2012, 10:44 AM
yes-- drive by cable-- -- i didnt get the gas pedal for the LS2 with it so i am not sure if im better to find a drive by wire gas pedal and corresponding wiring harness or convert to cable /lokar.
will need a wiring harness anyway.. ls2- tko600- 68 camaro
garys 68
06-28-2012, 11:39 AM
What ecu are you running. Newer ones dont have IAC capability.
cartel
06-28-2012, 11:55 AM
i need to buy a computer as well --
i was supposed to get the wiring harness and ecu but the wrecker sold that separate from motor.
bww3588
06-29-2012, 04:12 AM
Bbk makes a 90 mm cable tb with the correct 4 bolt pattern.
As far as your wiring problem, you can get a computer and a harness out of a 4th gen ls1 vehicle that will run the cable tb. Just have to get the 58x to 24x converter box and everything should plug n play.
garys 68
06-29-2012, 06:39 AM
As pointed out, if you have a 58x motor, I'm not sure if there are ecus that support iac. If you start adding up converters etc, it might be cheaper/easier to get the correct harness, ecu, pedal for your motor.
96 Comp T/A
06-29-2012, 07:54 AM
Any of the 4 bolt cable aftermarket throttle bodies should work. I run a FAST 92MM on my stock ported LS2 manifold. No adapter or spacer. You are going to need a Gen3 PCM with IAC drivers and code to run them though, and a throttle cable bracket. I use the 411 PCM out of the 4th Gen Camaro T/A.
psiconversion
06-29-2012, 08:09 AM
Agree with much above. If you have a 24X engine, you wont need a converter just a 411 PCM and a harness with provisions for knock sensors mounted on either side of the engine and a front mounted Cam sensor. If you have a 58X engine, you will need the same plus a Lingenfelter converter box. We can help you with all these items. Give us a call if you like.
Jon
PSI
732-691-6531
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
