New LS1 Owners - Newbie Tech - pulling motor from the top?
MackTruck49
06-28-2012, 01:11 AM
So anything I need to know about pulling the motor from the top, instead of dropping it out since i really dont have the option in the garage to do so...i would assume its not coming out with the tranny connected, and does radiator need to be pulled? Ill prob pull it anyways just incase, but kinda wanna pull it and get some things going project wise.
lemons12
06-28-2012, 01:18 AM
Spot on... Just did a buddies the other day and put it back in... Doing mine in the next few days.
Blk98Vert
06-28-2012, 03:37 AM
Why do you not have the option? I did it in my driveway with a cherry picker and a towstrap
bww3588
06-28-2012, 04:02 AM
Come along and a roof truss for me.
MackTruck49
06-28-2012, 11:18 AM
well i guess i have the option, i think i would just rather pull it out the top...
bww3588
06-28-2012, 11:26 AM
You'll say that until you take one out from the bottom a time or two.
TyCZ28
06-28-2012, 11:34 AM
ive only seen one come out the top.. and that was stripped down to the shortblock....
SStressin
06-28-2012, 11:38 AM
ive pulled it throughthe top over 5 times already. dont it with heads on and tranny connected... just need to get the passenger side motor mount stand off and get a really steep angle on it to pull it with tranny
JeremyKrauss
06-28-2012, 12:01 PM
Pulled it from the top twice in the last year with a come along and a nice solid wooden beam. Unfortunately, we don't have a cherry picker. Heads are off, radiator is out, and tranny is disconnected. With all of that off, takes all of two minutes to pull it out and roll the car away.
MackTruck49
06-28-2012, 11:47 PM
yea and no disconnecting brake lines or anything...ill be pulling it from the top when it comes out.
bernarlitt
06-29-2012, 04:04 AM
Did mine from the top also. Disconnect the battery, unhook the wires, Pull the Intake off, disconnect the trans,unbolt the headers, pull the radiator and condenser (keep the heads and accessories attached!!). Hook up a chain to the front and back of the motor and pull away! You will have to angle it coming out cause its gonna hit the top of the firewall coming out. Good luck!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
