$8000 for 4 hp???
Old 06-28-2012, 08:51 AM
Checkers's Avatar
Default $8000 for 4 hp???
So I have a c5z with a cam head work and full exhaust that I know of and it pulled 496 hp and tq on a mustang dyno. Threw twin 42 turbos on it and the tuner was proud to tell me last night he made 500 hp on a dynajet dyno. 8 psi springs but was only pushing 6 psi. But even w 6 psi I would def expect more than 4 hp. Can anyone tell me wtf is happening?
Old 06-28-2012, 09:03 AM
123quattro's Avatar
Um, the guy is an idiot. Find someone else to work with.
Old 06-28-2012, 09:15 AM
pwrtrip75's Avatar
With out knowing what he did to the tune, timing? A/F? Where is it seeing 6psi at? the turbo? And is there a boost leak upstream?
The guy could be an idiot too? Hard to say. i sure wouldnt be bragging about making 500hp if I did all that and the car had 496 when it came in....lol. Plug wire disconnected or something?
Old 06-28-2012, 09:54 AM
Checkers's Avatar
Plugs and wires are fine. Seeing boost on the gauge out of the vacuum system of the car. Said it ran great, afr's were beautiful and everything. Plus this is my second tuner.
Old 06-28-2012, 10:02 AM
1CAMWNDR's Avatar
Uh.....wow. Double,triple check for boost leak between turbo, intercooler, and throttle body. Check plugs. What plugs are in the car? Something is way off and I hope it does not cause a failure......
Old 06-28-2012, 10:12 AM
Checkers's Avatar
NGK TR5EK I believe. It's 2 heat ranges colder than stock.
Old 06-28-2012, 10:13 AM
Sluggish's Avatar
496rwhp with a head/cam n/a setup on a mustang dyno is the questionable part.
Old 06-28-2012, 10:16 AM
got-a-ls1's Avatar
lol am i the only one questioning the first 496 rwhp dyno on a typically low reading mustang dyno??? that isnt exactly a normal number for your typical head cam ls motor. i would say 6 psi on a ls and 500 rwhp isnt to terribly bad.... what parts are on your motor right now... heads? cam?
got-a-ls1's Avatar
sluggish damn you! haha
Old 06-28-2012, 10:17 AM
westtexasbuff's Avatar
You are dynoing on two different dynos. He probably mistakenly told you 496whp the first time instead of 396whp. Mustand dynos are stingy. How does it feel on the new setup? Take it to the track.
Old 06-28-2012, 10:21 AM
Checkers's Avatar
Not even drove it yet. Still being tweaked at the tuner. I was wondering about the first dyno too but the car ran great before. 7.7 @ 100 mph in the 1/8 on firehawk RF's. Sure expected alot more than 500 though.
Old 06-28-2012, 10:22 AM
632b00's Avatar
Old 06-28-2012, 10:28 AM
got-a-ls1's Avatar
6 psi is nothing lol.. turn it up past 10-12 and watch the numbers climb. also just because the springs are 8psi spring dont mean ****. thats a rough estimate. not every spring will make exactly the rating in different setups.. dial in your boost with a manual boost controller
Old 06-28-2012, 10:45 AM
Captain Double Post
BOBS99SS's Avatar
Thats one badass na setup to get those numbers on a mustang, do you have that dyno sheet?not doubting you but something is jacked up
Old 06-28-2012, 10:49 AM
Checkers's Avatar
Ya I've got it but no idea how to put a pic on here. The shop is very questionable though. Found out the hard way.
Old 06-28-2012, 11:34 AM
josepy121380's Avatar
Yeah there is no way your car made 496 on motor. Drive it once at 500 and I bet you will will feel the difference.
Old 06-28-2012, 11:46 AM
6D9 Matt's Avatar
Yeah definitely questioning the NA dyno numbers.
Old 06-28-2012, 11:53 AM
Frans96SS's Avatar
6 psi should still make at least 120hp... Generally 20-30 HP her PSI
Old 06-28-2012, 12:46 PM
Mavmavv's Avatar
Tell your tuner to hook up the cold side.
Old 06-28-2012, 12:52 PM
Frans96SS's Avatar
Originally Posted by mavmavv
tell your tuner to hook up the cold side.
hahahahah:d:d:d
Quick Reply: $8000 for 4 hp???
