Drag Racing Tech - 12.4 to 11's
View Full Version : 12.4 to 11's
232 racing
06-28-2012, 10:52 AM
stock bottom end ,799 heads unported ,long tubes,tune,slp lid and maf,ls6 intake,3700 stall, m/t ets 18 psi,tsunami cam 648/609,no seats in car minor weight reduction about 110 #,offroad y pipe with bullet muffler,stock rear end, 4l60,is there any way to get a few extra tenths to get there i flash the convertor car hooks good 7.9's in the 1/8,1.6-1.7 in 60' help me get in the elevens feel free to ask any questions if this is not enough info?
BlackScreaminMachine
06-28-2012, 11:05 AM
7.9's is good for 12.245 in the 1/4. Your looking @ 7.7's and to be honest that car is under stalled.
To run N/A a high stall converter is almost a requirement. Some more in the rear gear would not hurt either.
What height is the tire and what does the car 60 and mph? Any race weight measurement?
Any dyno #'s or are you sure there is no TQ management left in the tune?
TransAmcoupe98
06-28-2012, 12:24 PM
Agree with this, a 4k stall converter with some 4.10's would probably get your ET's down. That cam needs a bigger converter. Cam is too big for current setup IMO. Sometimes bigger isn't better. My buddy's T/A with a 228R cam only, 4k converter, with ET streets and full exhaust made an 11.90 pass in bradenton.
superGTO
06-28-2012, 02:50 PM
Agreed, without adding more to the engine in way of HP gears and a higher stall and you are there. Your 60s seem really good, so that's where I'd go.
jrob56
06-28-2012, 03:02 PM
its always funny to see a H/C car and pulled interior not make 11s, thats when you know your combo is way off. 4000 stall, full exhaust and right cam will go 11.9-11.8 all day and thats with full interior
TransAmcoupe98
06-28-2012, 03:08 PM
Yes. People are misinformed, a lot of times by companies wanting to make a buck off a cam. Some cool sounding cam name like The SavageV2 cam...248/258....yea man you don't need gears and a 3000 converter will work fine..."
11SECSS
07-03-2012, 04:42 PM
Just like others have said and I'll add in a factor saying your tune could be off some .
speedtigger
07-03-2012, 05:03 PM
What was your MPH? Post a timeslip. What are you shifting at?
TransAmcoupe98
07-04-2012, 07:06 AM
DA for that day also if you can.
