Cadillac CTS-V - WTB head lights
View Full Version : WTB head lights
hottelssss
06-28-2012, 11:42 AM
My headlights are foggy, so I'm wanting to replace them. I'd prefer to pick up a set that are smoked but don't have to be. Pm or text 573-450-0465 thanks
hottelssss
06-28-2012, 11:45 AM
Also smoked tails if someone by chance has a set for sale thanks.
Onefast V
06-28-2012, 01:24 PM
foggy like moisture inside or like oxidized outside? if the lenses are oxidized outside you can spend $20 for a 3M headlight polish kit and they will look brand new.
hottelssss
06-29-2012, 03:26 PM
Looks like both, I've tried the headlight restore kit with no luck. I'm crossing my fingers that someone has a set or knows where I can get them.
Onefast V
06-29-2012, 04:50 PM
ebay but you are talking about $800 i think
hottelssss
06-29-2012, 06:03 PM
I found a decent set on there, but I've gotta be sure they are correct. Is there any diff between cts and V lights? Other than the xenon?
bamacaddy
06-29-2012, 08:02 PM
I had the same issue with mine....It turned out to only be oxidized on the outside... The worst I've ever seen. I bought the 3m restore kit from O'reilly and it wasn't cutting it so I bought some adhesive backed sandpaper and cut it to fit on the 3m kit. I had to start with a MUCH more aggressive grit than comes with the kit and work my way to finer and finer paper. Took around 3 hours per light but I liked that idea way more than buying a set. If you're gonna buy a set anyway why not spend $20 on some lower grit and try it?
hottelssss
06-30-2012, 05:59 AM
In gonna give it a try, worst case scenario in out $20. I'll keep you posted thanks!
