Using 5.3 crank with 5.7 pistons and rods.
Old 06-28-2012, 01:37 PM
kossuth's Avatar
Default Using 5.3 crank with 5.7 pistons and rods.
Thinking of piecing together an iron block 5.7 using regular ls1 pistons and rods with the 5.3 crank. I know the 5.3 crank is the same as the 5.7 crank just differing in balance and also not being gun drilled. Has anybody ever mated this combo together and had it balance right or is it too much work to be feasible.
Old 06-28-2012, 02:03 PM
TransAmcoupe98's Avatar
Check out Thompson motorsports. They use an iron block 346. Heavier but can withhold more than stock aluminum block. Good for boost/nitrous. THey should be able to help you out more. Contact Kyle at Thompson Motorsports
Old 06-29-2012, 02:10 AM
bww3588's Avatar
it will work fine, just have it balanced.
Old 07-03-2012, 12:14 PM
thompson's Avatar
Feel free to give us a call, We keep them in stock in both iron and aluminum Gen III and IV. We sell them with everything from basic Hypereutectic pistons to all forged rotating assemblies, and everything in between. We are here to meet your exact needs with a motor.
Thank you,
Kyle
972-853-0518
Old 07-03-2012, 12:31 PM
Kyle Ill give you an update on the build soon so you can have it for reference.
Quick Reply: Using 5.3 crank with 5.7 pistons and rods.
