1999WHITEFRC
06-28-2012, 05:50 PM
2000 Formula 9 second N/A car Ready for Nitrous
Chassis
Rust free Hardtop car White/ Black interior
Killer 8.50 Cert Chrome moly cage (just certified last week)
VFN 5 Inch Hood
Kirkey seats
Factory Dash
Removable Steering wheel
Lexan windshield
Autometer water/oil/vacuum/NOS gauges/shiftlight
Burkhart front bumper support
Spohn sub frame connectors
Motor
LSX Block
4.200 Bore 4.125 stroke
Callies Crank / Rods
Wiseco Pistons / Coated
Compression between 12 to 12.5
Bullet Solid Roller Nitrous Cam
Katech timing chain
Melling oil pump
ATI Balancer
Moroso Vacuum Pump
Moroso Aluminum Pan
Meziere Race Water Pump
Trick Flow 245cc CNC Heads 6 bolt Done by TEA
Jesel Mohawk Rockers
Comp lifters
Moroso Aluminum Valve Covers
Beck Sheet metal intake with 4500 series flange
4500 Accel 2600cfm Throttle Body custom linkage
60 lb injectors
Speed Density Tune done by Rapid Motorsports
Exhaust
Kooks 2 inch stainless headers with 3 1/2 collectors
Edelbrock Mufflers (actually quiet for what they are)
Transmission
TH 400
Reverse Manual Valve body with trans brake
34 element drum and sprag
Alto red clutches
Deep cast Aluminum pan with drain
Some roller upgrades in trans
CSI Carbon Fiber Shield
Hurst Quarter stick shifter
TCI SFI Flex Plate
Spohn Chrome Moly Drive Shaft
Trans Specialties Super 8 NOS converter actually a 9 inch
B&M Super cooler trans cooler with all Braided lines
Rear
Burkhart Fabricated 9inch rear with anti roll bar
Fill and Drain plugs
Tie Down loops
Powdercoated Black
Moser 3.70 gears
Moser Nodular Center Section
Moser 35 spline axles/ Spool
Moser Yoke
Fuel System
Nasty Performance Tank
Magnafuel 625 EFI Pump with filters front and back
Fuel Lab EFI Regulator
All Earls Black Braided Line
-12 from tank to pump
-10 from pump to motor
-8 return
All Earls or Aeromotive AN fittings
Nitrous Fuel system
Harris Speed Works stand alone (not hooked up)
NOS MINI 2 STAGE PROGRESSIVE CONTROLLER
Nitrous system
Nitrous Outlet Dual Stage Plate for Beck intake (not hooked up)
Front Suspension
Spohn K-Member (Mild steel)
Spohn Tubular upper and lower control arms, lowers are Adjustable
Spohn Solid Motor mounts
Spohn Manual Rack
Strange Single adjustable coil over shocks #275lb springs
Madman travel limiters
Rear Suspension
Spohn Pro-Series Adjustable Torque Arm with loop
Burkhart Off set Double Adjustable lowers (chrome moly)
Spohn Pan hard Bar (Chrome moly)
Strange Double adjustable rear shocks
BMR Lowering springs
Brakes
Aerospace on all 4 corners with stainless steel brake lines
Burkhart Manual Master cylinder with Linelock
Wheels and Tires
Weld Magnums 15x10 rear with 275 Hoosier Drag Radials with 6 pass's
Weld Magnum fronts 15x4 with Moroso DS 2's
Performance only 6 pass's Last weekend in 90+ degree heat
Best 1/4 ET 9.79@139 (on motor)
Best 1/8 et 6.26@111 (on motor)
Best 60ft 1.418 (on motor)
All pass's made off foot brake.
Remember this is a Nitrous car with a tight converter, Nos cam, and only 3.70 gears. Shift light wasnt even on going through the traps. Easy 8 second car.
This is a no BS car, motor and trans are new only 6 pass's and about 20 street miles. Rear may have about 20 pass's and about 150 street miles. I have driven it on the street with no issues. All lights and turn signals work. I have nothing to hide. Anyone that looks what this car has, knows I have double the asking price into it, not to mention countless hours of labor. I did not plan on selling this car ever. This car is race ready, chassis certified a week ago, and the belts are good. Car goes straight as an arrow down the track. I just had a 4 wheel alinement done by a reputable shop. Buy it and go to the track. I do not plan as of now taking it again. This will be an easy 8 second car on Nitrous. All you have to do is finish the 2 fuels lines and your ready to go. I will post more pics of the car this weekend, as I only have a few on my computer now.
NO TRADES, so please dont offer any. Also serious need apply only. If you are really interested pm for my number. All I ask is dont waste my time if you dont have the funds or are not serious. Asking $19,900. Cash is King. Shoot me an offer. I also have a 2009 Haulmark Race Trailer ,its White , 24 foot, 10000lb axles, finished sides and roof, ply wood floor, I could make a combo deal with the car. LED lights all around.
Chassis
VFN 5 Inch Hood
Kirkey seats
Factory Dash
Lexan windshield
Motor
LSX Block
Katech timing chain
Melling oil pump
ATI Balancer
Moroso Vacuum Pump
Moroso Aluminum Pan
Comp lifters
60 lb injectors
Exhaust
Transmission
TH 400
Alto red clutches
TCI SFI Flex Plate
Rear
Tie Down loops
Powdercoated Black
Moser 3.70 gears
Moser Yoke
Fuel System
-8 return
Nitrous Fuel system
Nitrous system
Front Suspension
Spohn Manual Rack
Rear Suspension
Brakes
Wheels and Tires
