Lightly used NOS system Components!
Category: Racing Parts
Price: $2
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, Front wheel drive vehicles
Location (State): Can-AB
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Here are the parts I have left...
MSD 8969 Digital RPM Window Switch: Retails $134.99. Price $95 + shipping
- This switch requires no RPM modules. Its RPM activation points are programmed simply by scrolling through the LED display to RPM amounts (from 200 to 15,000 RPM in increments of 100). The switch accepts an input RPM signal through a: coil negative terminal (for stock ignitions), tach output of an ignition control, 5-volt tach signal, or ECU. The switch can be used with an input voltage of 9-18 volts, and it has two outputs (one normally open, one normally closed). You can even control a shot of nitrous on nearly any engine combination.
Cold Fusion Digital Progressive NOS Controller Retails: $239.95 -Price $175 + shipping
FROM COLD FUSION NITROUS SYSTEMS. This unit was designed to allow the aggressive use of nitrous power and putting it on the ground. A simplified wiring harness and easy to adjust push button LED controls makes this device a breeze to install and use. The start percentage can be adjusted from 1% to 100% in 1% increments. The Nitrous build time can be adjusted from 0.0tenths (instant 100%) to 8.0 seconds in 0.1 tenths of a second increments. ORDER ONLINE NOW OR CALL 1-866-606-3991 It also has 2 modes for automatic cut off or continue the count down. It is activated by your WOT switch or your push button switch that activates your nitrous kit. The high amperage drivers can handle all of today's high amperage solenoids. Infact, this controller is so heavy duty it can control 4 large PRO solenoids used on a V8 FOGGER KIT!!! Overall dimensions are 4"x3"x 1.75". Shop around and you will find that this is the best deal on the market today! This device is perfect for your nitrous installation and is a must have if you are running shots over 50HP for your engine's safety and longevity. The "hit" of nitrous is what damages components and what has given Nitrous a bad name, but with this heavy duty digital controller you won't have to worry about any of that.dum
Dynotune Lean Shut-Down Switch Retails: $99 - Price: $65
The DuynoTune Air/Fuel Lean switch is a device that will shut off your nitrous system if it detects a lean condition during your run or spraying. It can double as a basic Narrow or Wideband depending on the type of sensor you are running in your exhaust system. The A/F ratio is displayed in a digital format.
Dynotune Nitrous Oxide Solenoid 150hp (p/n200) Retails $69 - Price $40
Compare the features, Stainless construction, High power coils, powder coated housing, High flow, like a nos branddum(superpowershot)! The SuperPowershot/Cheater style solonoids use 1/8"npt inlet/outlet ports. .078" orifice
Dynotune Fuel Solenoid 175hp (p/n201) Retails $79 - Price $45
Why buy DynoTune Solenoids? They are the best available. Ask the competition what seal material they use in the fuel solenoid? If they say Fuel Viton you could be in trouble. With all the chemical additives in fuels today they attack the fuel seals in days! This will cause the solenoid plunger to swell and stick. The result is a solenoid that will not open! DynoTune uses a very expensive custom seal that took years to develope. Ours works with alcahol, race fuels, octane booster, nitro methane etc. The SuperPower shot/Cheater style solonoids use 1/8"npt inlet/outlet ports. The competion does not give you all this because they mass produced over seas.
.178" orifice
(2) Dynotune Fogger Nozzles "Black" (p/n506.2) retail: $29 each - Price $20 ea.
Fogger nozzle for wet nitrous kts. Black Show Finish and built using DT technology.
Nitrous Lines from DynoTune:
(2) 3AN Nitrous lines 2 footers with Blue fittings (p/n595) retail: $22 each - Price $15 ea
These braided nitrous lines are 2 feet long and have blue fittings. Perfect for nitrous solenoid to fogger nozzle connections. 3AN female to 1/8" npt male
(2) 3AN Nitrous lines 2 footers with Red fittings (p/n596) retail: $22 each - Price $15 ea
These braided fuel lines are 2 feet long and have red fittings. Perfect for nitrous solenoid to fogger nozzle connections. 3AN female to 1/8" npt male
(1) 4AN Fuel Feed line 2 foot with a Red Fitting (p/n594) retail: $22 each - Price $15 ea
From Dyno Tune Nitrous: Various Nitrous Flare Jets: Brass (p/n599) retail 3.99 ea - Price $2.50 each
(4) .042
(4) .022
(2) .034
(4) x .024
(2) x .012
(2) x .016
Notes:
1) Shipping at your expense by method of choice.
2) I have printed install manuals for all the electronics that I can include or send as a pdf file.
3) Paypal accepted
4) don't bother low balling as I priced fairly!
Thanks for looking,
Trev
