Carbureted LSX forum - fuel pressure issues
89gmcs15
06-28-2012, 10:01 PM
ive got some questions. my edelbrock quietflo 160gph pump seems to be having trouble keeping up to my pressure needs even at idle. it starts off fine at 7.5 psi, but then after a few minutes of idling it slowly falls to like 4 lbs and ive even seen it read 0 on more than one occasion. its a all new fuel system from the ground up even the carb and fuel cell. the floats are set perfect on the carb when its at 7.5 psi and they dont really seem to change when the pressure gets low or even at 0 so im confused. is 8an fuel line too big for a pump like this to keep pressure? i couldnt see that being a problem but i have to ask. ive purchased everything but the tank carb and lines 2 times now and ive got way more money dumped into this problem than i should have. its frustrating spendin 200 bucks on a pump only to find out that wasnt the problem. tell me im stupid and the gauge should be bad or some shit please. thats the only thing in the system that isnt brand new i will be buying a new gauge before the weekend tho. if thats the case im gunna be pissed at myself for not trying the cheapest simplest route first... i can get pics or even vids of the pressure/system if needed, i just need this sorted out. thanks for lookin and any help will be awesome.
3pedals
06-28-2012, 10:34 PM
7.5psi is too much at the carb, turn it down to 5- 5.5psi.
Is this a deadhead, or return style system?
if the pressure is falling, you either have a pickup problem preventing the pump from moving fuel, or the pump itself is not moving the fuel for what ever reason - wiring/voltage issue maybe?
89gmcs15
06-28-2012, 10:57 PM
i guess i was just going by what pro systems said for the fuel pressure. its a returnless style/deadhead setup too. im going to buy a new gauge tomorow or this weekend and double check that too. if that doesnt work i will try to turn down the pressure and double check my wires and current draw... i also pulled the line from before and after the regulator and filled a couple 5 gallon cans pretty quickly. it had a nice flow with both the old and new pump when i tested it too...
3pedals
06-28-2012, 11:12 PM
good call on the gauge, if it is moving good volume of fuel, then thats where I'd look.
The reason I suggest 5-5.5 psi of pressure, is that at about 8-9 psi the needle an seat in the carb starts to loose its ability to close against the pressure. Some guys run more, some less, I like 5.5psi.
dr.dub
06-28-2012, 11:14 PM
Just pull line on carb and run it into a gas can quick and simple way to see if it's really zero
ss_454
06-29-2012, 02:22 AM
I have seen wiring cause a problem like this the pump was loosing ground as it vibrated and pressure would jump around as the wire rattled at the ground. I would just check your wiring quick make sure its all good ?
Pop N Wood
06-29-2012, 05:52 AM
Liquid filled gauges can be pretty unreliable when they get hot. You can try a different gauge in a place where it won't get hot.
Larger line can only help the pump, not hurt it. Excessive flow can cause a low pressure, but if nothing is moving the line should fill up and hold pressure.
If you have any type of air leak in the line before the pump, a loose fitting or something, then that can cause erratic pressure.
If the problem is a loose power wire or ground then I would think you could hear it in the sound of the pump.
Is the tank properly vented? If you draw a vac in there the pump can stop pumping.
Another obvious problem is the regulator could be bad. If you got a second pressure gauge and put one before and after the regulator you could quickly eliminate the regulator as the problem.
Last thing is maybe you need to go to a return style regulator. That is a pretty big pump to be running into a dead head. At idle the pump is just sitting there spinning against the same slug of fuel in the rotor. Maybe it is heating up and boiling basically. If you have ever heard a pump that is cavitating it is a pretty distinct sound.
Is the pump near the bottom of the tank or is it mounted higher than the tank? Keeping a positive pressure at the inlet to the pump helps.
Do you have a prefilter and is it clogged?
Last I think Speedtigger had that same edlebrock pump and swapped it out for the same reason, it didn't keep a steady pressure. You might search on some of his posts to see if that was really the case.
89gmcs15
06-29-2012, 07:03 PM
sorry for the crappy way to reply but here it goes, all questions are answered in order ha so scroll alittle to figure it out. thanks again for the help it was what i needed.
this seemed to be the problem. stupid me thought i was goin with the cheapest part first and forgot the gauge could have went to shit.
i was confused about it hurting since it goes thru such small jets in the carb compaired to the fuel line size
tripple double checked this thanks tho
tank has one 8an line as the vent with a breather filter on the end of it to keep dust from going in
this was my initial thought, so i bought a new one and it didnt change the issue....
i will look into this if the problem comes back
i was worried about the wiring going to the pump seeming small but its bigger than the wires on the pump from factory so i kinda tossed that out the window. and the truck is too loud to hear changes in the pump even at idle with the exhaust on
pump is at about the bottom of the tank maybe a few inches higher than the end of the pickup
brand new pump, but i did check the old pumps pre-filter screen tho. it was clean
i will look into this too, kinda sucks since i just spent another 200 on a pump and another 90 on 2 new quick fuel regulators. on the plus side i did find out that it was all just a bad gauge or the fluid filled gauge was heating up too much and causing pressure reading problems. stupid summit junk haha
3pedals
06-29-2012, 08:08 PM
Lol, I have not figured out how to multi quote either, lol
So I take it the guage was the issue?
89gmcs15
06-29-2012, 08:46 PM
Seems that with a new gauge the fuel pressure holds steady. Im bummed that this is what the whole problem was and it cost me over 290 and time to fix a 10 dollar part but oh well live and learn. now I have a issue at wot at higher rpms... falls on its face at about 5500/5800 rpm. Gotta check my floats again since the fuel pressure has changed it seems like the fuel level is a touch low. I cant quite see the level in the sight glasses now... Maybe thats my high rpm stumble/issue I guess thanks for all the help so far.
Pop N Wood
06-29-2012, 09:01 PM
The rev limiter on the MSD box comes preset at 5500 RPM. Check that first, it seems to hit everyone when they first get running.
89gmcs15
06-29-2012, 09:43 PM
Ill have to look at it again. Unless it lost its memory somehow it should be still at 6800. It almost acts like its a fuel issue somehow. maybe I need to check my plugs for fouling since my pressure was so far o uh t of whack.... When I put the new gauge on my pressure was way up at like 12 and I had to turn it down a ways before it reacted on the gauge. Could fouling be causing a high rpm issue?
speedtigger
06-29-2012, 09:51 PM
I had a rail mounted liquid filled gauge that did that too. I pulled the plug out of the back of the gauge to let the liquid filling out and it has been fine ever since.
BackNBlue
06-29-2012, 10:13 PM
I would turn the fuel pressure back up to 7ish.
89gmcs15
06-29-2012, 10:37 PM
Ill prolly just buy a good gauge, ive got a oilfield supply store 30# dry with a collar reducer bushing and a nipple to test it out. Ive akso got the fuel set to 7.5 psi just like before. Im going to doublecheck the float levels tomorow and get them right cuz I know theyre alittle low. Ill report back tomorow with what I find and prolly pull plugs and check them. Anyvidea of what I should run for plugs and gap? Carbed lq9/ls3 with good sized cam th400 with a decent stall rated at 3600 RPMs and conservative timing set at 29 degrees all in by 3k. Sorry for typos and missed letters im on my phone
3pedals
06-30-2012, 01:00 AM
I run TR55's at .030" gap. my engine is 11:1 for reference
on the timing, I like locked out full at idle. my setup likes 32*
89gmcs15
06-30-2012, 11:05 AM
ill have to look into those plugs cuz im totally not sure whats in it since i got them a year ago ha. my setup is at like 10.38 cr. it runs pretty good for what it is i just gotta get these little issues worked out so i can really mash on it
BackNBlue
06-30-2012, 07:26 PM
I have read quite a few posts about spark plugs here where the common gap for these engines seems to be .050" because the coil packs are more powerful than an old HEI or points set up.
speedtigger
06-30-2012, 08:11 PM
If you are only running .030" gap, why not just run TR5s?
S10xGN
06-30-2012, 08:16 PM
3p,
For each post you want to quote, click the middle button, looks like a, well, quote mark (double apostrophe). When you get to the last message you want to quote, use the regular button on the left side that says "quote".
3pedals
06-30-2012, 09:06 PM
If you are only running .030" gap, why not just run TR5s?I started with the 55's since it was Oem spec on the LS1 which is close to the compression In my engine, they looked excellent during
my engine dyno runs so I stuck with them. The .030 was to ensure that there would be no ignition issues, as any ignition weakness will show with high cylinder pressures, and wide gaps, tighter gaps keep things happy, and I have not seen any negatives yet.
3p,
Thank you
bluethunder364
07-03-2012, 08:43 PM
Have the same issue with my car!! Falls on it's face @ around 5,500 rpm.......new 140GPH SS Areomotive pump, new 1/2" fuel line and billet filter. I'm really pissed as I can't find out whats going on. Did the flow test from the reg. to the carb and I have 2 gallons to the fuel jug in about 55 seconds. Fuel is coming like Niagra falls out of my 1/2" line. Pulling the carb tomorr. to see if I can see anything abnormal. Don't really know what to do next. And yes the MSD box is set for 6500 RPM from the laptop. Freaking cars!!!!!
89gmcs15
07-03-2012, 09:25 PM
I still cant get mine right. And in the last 10 times ive driven it the fuel has only dropped pressure once. Its at random its doing it and now everything is new, fuel tank all the way to the pistons haha. Idk what else to do other than go thru wires again and run more grounds.
