Gears & Axles - Quick Performance 9"/MWC T/A Install
coolmanvette75
06-28-2012, 11:27 PM
Figured I would post up some pics of my rear end install from yesterday. The rear is a Quick Performance housing, Yukon nodular iron n-case, Moser 35 spline axles, Motive 4.11 gears, and a QP 35 spline drag spool. The t/a is a MWC crossmember mount unit. This is their special mount for cars running true duals. Everything went in like a glove. Rear bolted right up and the t/a went right in. Didnt even have to drop the exhaust.
Stock 10 bolt:
https://sphotos.xx.fbcdn.net/hphotos-prn1/s720x720/532460_251146915000267_345627409_n.jpg
The QP rear end unassembled:
https://sphotos.xx.fbcdn.net/hphotos-ash3/s720x720/563916_251146851666940_907677888_n.jpg
T/a mount, Wolfe drag bar (not yet installed), and the MWC t/a unit:
https://sphotos.xx.fbcdn.net/hphotos-snc6/s720x720/181297_251146885000270_603954453_n.jpg
10 bolt out:
https://sphotos.xx.fbcdn.net/hphotos-snc7/s720x720/428520_251147015000257_1873326431_n.jpg
Stock 26 spline vs Moser 35 spline:
https://sphotos.xx.fbcdn.net/hphotos-snc7/s720x720/600206_251147028333589_1462283864_n.jpg
Center section (assembled by QP):
https://sphotos.xx.fbcdn.net/hphotos-ash3/s720x720/555811_251147041666921_1520316463_n.jpg
Center section installed:
https://sphotos.xx.fbcdn.net/hphotos-ash4/s720x720/425127_251147061666919_1868317994_n.jpg
9" going in:
https://sphotos.xx.fbcdn.net/hphotos-ash3/s720x720/529362_251147245000234_652644532_n.jpg
Hooking up lca's and shocks:
https://sphotos.xx.fbcdn.net/hphotos-ash3/s720x720/523716_251147281666897_1537084749_n.jpg
MWC crossmember fits like a glove around the 3" true duals:
https://sphotos.xx.fbcdn.net/hphotos-ash4/s720x720/269386_251147361666889_1974210250_n.jpg
Some other views of the crossmember:
https://sphotos.xx.fbcdn.net/hphotos-snc7/s720x720/399308_251147381666887_1023130422_n.jpg
https://sphotos.xx.fbcdn.net/hphotos-prn1/s720x720/562764_251147405000218_1952188192_n.jpg
T/A hooked up:
https://sphotos.xx.fbcdn.net/hphotos-ash4/s720x720/406033_251147431666882_1914308732_n.jpg
Everything hooked up:
https://sphotos.xx.fbcdn.net/hphotos-snc7/s720x720/488018_251147461666879_1601971442_n.jpg
https://sphotos.xx.fbcdn.net/hphotos-prn1/s720x720/561741_251147485000210_598554125_n.jpg
https://sphotos.xx.fbcdn.net/hphotos-snc6/s720x720/252622_251147515000207_860648377_n.jpg
Pinion angle set to -1.5*
https://sphotos.xx.fbcdn.net/hphotos-ash4/s720x720/255197_251147548333537_1890398139_n.jpg
All done:
https://sphotos.xx.fbcdn.net/hphotos-ash4/s720x720/428930_3402551474816_1690978102_n.jpg
coolmanvette75
06-28-2012, 11:30 PM
I will be fitting and welding in the wolfe drag bar some time this week so stay tuned for that. Please let me know if you guys have any questions or need any pics of anything in particular...
Shownomercy
06-29-2012, 09:57 AM
Pics of a sub 3.0 60ft time slip would be nice.
coolmanvette75
06-29-2012, 03:05 PM
Gimme a week pal. Might go to Atco on thursday...
tektrans
07-01-2012, 06:22 PM
Very nice install-great pics. GL at track.
wysemunky
07-02-2012, 06:54 AM
Nice! time for some sticky tires.
coolmanvette75
07-02-2012, 10:19 PM
Thanks guys. I think these should be sticky enough ;)
https://sphotos.xx.fbcdn.net/hphotos-snc7/s720x720/376945_3415733404356_766751266_n.jpg
lethal bird
07-03-2012, 09:59 PM
Sweet cant wait to get mine. Exactly same setup as yours.
lethal bird
07-07-2012, 10:05 PM
Went to go price my set up and there site is down.........
coolmanvette75
07-09-2012, 09:59 AM
Seems to be back up now
RynoGTO
07-15-2012, 12:13 AM
Correct me, if I'm wrong, but are the rear calipers mounted on the wrong side of the rotors? They're mounted on the outside (towards the rear of the car) in the pics, but I believe they're supposed to be mounted on the inside (towards the doors). Right?
GMRACER13
07-15-2012, 12:04 PM
The calipers are installed correctly. On LT1 cars the calipers are mounted towards the rear.
RynoGTO
07-15-2012, 03:11 PM
Wow, I never knew that. Learn something new everyday.
agressive
07-19-2012, 07:10 PM
Quick question how much did it cost u to assembled ur 9" parts & labor?
coolmanvette75
07-19-2012, 09:50 PM
The center section was assembled by qp. Everything from housing, to axles, to 3rd member was 1990 shipped. The actually assembly of the rear (bolting on 3rd member and putting in axles I did myself
dw2000ta
07-21-2012, 12:06 PM
just under 2 k shipped and installed.... Not to shabby for a 9".. nice work.
Mighty Whitey
07-26-2012, 09:12 PM
Edit: Nevermind, I now see that it's a stock style MWC torque arm.
coolmanvette75
01-12-2013, 02:09 AM
Just realized I never updated this thread with the drag bar pictures. Better late than never I guess!
The one downside to the QP 9" is if you, like me, are trying to mount a solid drag bar style sway bar. Because of the T/A mount, it does not allow it to mount to its intended location without some minor modifications.
As you can see here, I had to slightly grind down the back side of the T/A mount to get the drag bar in its proper place
https://sphotos-b.xx.fbcdn.net/hphotos-ash4/255292_256764877771804_1425403193_n.jpg
Clearance was real tight, but we made it work
https://sphotos-b.xx.fbcdn.net/hphotos-ash3/531607_256764927771799_279511483_n.jpg
Welding the bracket to the axle tube
https://sphotos-a.xx.fbcdn.net/hphotos-prn1/523813_256764801105145_2009417397_n.jpg
Another issue was the chassis links supplied by Wolfe. Again, because of the T/A mount, the bar was placed slightly further back then on your standard rear. Not a problem. We just ordered some longer links and were back in business
https://sphotos-a.xx.fbcdn.net/hphotos-ash4/428862_256764991105126_1843247102_n.jpg
After everything was welded up and adjusted, this was the finished product. Looks badass and performs just as good as it looks
https://sphotos-a.xx.fbcdn.net/hphotos-ash3/575949_256764951105130_1471104561_n.jpg
Mrmooney
01-12-2013, 02:51 AM
Looks good, can't wait to order my 9"
bwolfZ28
01-12-2013, 01:25 PM
Everything looks good. I'm ordering a rear from them next week. Did you get a standard width rear? Also what are the specs on your wheels tires in the rear?
Blackpanther99
01-12-2013, 08:52 PM
Awesome! Cant wait to order my 9" :D
Did you narrow the axles? Is it a spool?
NnOoSsSs
01-12-2013, 09:15 PM
:nod: :cheers:
coolmanvette75
01-13-2013, 03:25 AM
Yes the car has a spool and not it is not narrowed (yet). Stock length rear with 28x11.5 Mickey Thompson ET Drags. Mounted on 15x10 Weld Drag Lites with a 7.5bs. Gonna be hopefully having the rear chopped 3in on each side and running 325/50/15 Hoosiers on 15x10 Weld Vektor RT's with a 4.5bs...
studderin
01-17-2013, 12:10 AM
parts look nice
haha, did you know I think its your car in a 1320 motavital posted I saw the other day.
coolmanvette75
01-17-2013, 03:55 PM
parts look nice
Hahaha yea. I'm friends with Kyle (owner of 1320video) and we were fucking around. He made it and said "I hope you have a good sense of humor." I got a kick out of it. Lol
