lollygagger8
06-29-2012, 08:05 AM
So your stock motor mounts look like this?
If they don't yet, they will
http://i132.photobucket.com/albums/q16/n2havnfun2/Motor%20Mounts/motormount.jpg
Time to change them out for some nice new Rev Shift Motor Mounts!
(the Nylon Nuts on the RevTechs is 3/4"):
http://i132.photobucket.com/albums/q16/n2havnfun2/Motor%20Mounts/RevShiftMMs2.jpg
Tools you'll need:
15mm socket
18mm socket
3/4" socket
Jack with piece of wood to distribute weight
External Torx E-10 (or a 8mm socket)
Extensions
Now you have a decision to make.....
Some people take the stock manifolds/or headers off to do this which makes life a lot easier but takes more time
(lots of extensions and an impact, when removing the motor mount brackets from the block)
Or leave the manifold/headers on and get up close and personal with a wrench.
Remove the wheel and dive on in.
This is showing Passenger Side (3 bolts):
Old Motor Mount bolts on block: 15mm
http://i132.photobucket.com/albums/q16/n2havnfun2/Motor%20Mounts/UUCMotorMountPassengerSide.jpg
This is showing Driver's Side (4 bolts):
Make sure the bolts with studded head go on bottom so the wire loom can be reattached
http://i132.photobucket.com/albums/q16/n2havnfun2/Motor%20Mounts/UUCMotorMountDriversSidefront.jpg
Here are the new Revshift Mounts inside both brackets. It's upside down in the pic (sorry I was in a hurry and was trying to take pics on the side)
RevTech also told me the factory heat shields are not necessary and were not installed
http://i132.photobucket.com/albums/q16/n2havnfun2/Motor%20Mounts/RevShiftMMs3.jpg
The Nut on the hex stud is 18mm
http://i132.photobucket.com/albums/q16/n2havnfun2/Motor%20Mounts/RevShiftMMs8.jpg
This is the same stud removed (you can use a 8mm socket on it if you don't have an E-10 inverted torx socket):
http://i132.photobucket.com/albums/q16/n2havnfun2/Motor%20Mounts/RevShiftMMs11.jpg
Here's how I lifted the engine block (and how I've done it every MM change)
My buddy Lance's head is now famous
http://i132.photobucket.com/albums/q16/n2havnfun2/Motor%20Mounts/RevShiftMMs6.jpg
Gratuitous Dipstick shot (some people say they've done it without removing, but I've taken mine out every time since it's like playing Jenga getting the MM bracket out...that bolt is 15mm)
Wrapped headers FTW
http://i132.photobucket.com/albums/q16/n2havnfun2/Motor%20Mounts/RevShiftMMs12.jpg
This is trying to maneuver the passenger side motor mount block from the engine bay (That nut on top is 18mm):
http://i132.photobucket.com/albums/q16/n2havnfun2/Motor%20Mounts/RevShiftMMs9.jpg
RevShift mount installed,,,very nice!:
http://i132.photobucket.com/albums/q16/n2havnfun2/Motor%20Mounts/RevShiftMMs14.jpg
Initial thoughts after I've put 400+ miles on these so far.......
The idle vibration is raised slightly compared to the UUC's. Now I realize this is all subjective....so a little insight:
The UUC's only vibrated slightly more than the stockers, so being the Rev Tech's being a harder urethane than the UUC's you feel the idle just a tad more like as if you had a tiny cam maybe?
The engine feels like it's more planted though like the power is getting transplanted to the ground a lot better. Placebo effect? I don't know.....but I like it.
I got the 80A blue ones (softer street ones) which are only $149.99....can't beat that price!
RevShift makes red ones (track ones) and even harder. So pick your poison.
All in all I'm happy with them because I like my power getting to the pavement. My UUC's weren't bad (I thought they were) but these are much firmer which hopefully translates to HP being used intsead of lost. (Like my butt dyno suggests) I'm digging em!
Here's a link to buy em:
https://www.revshift.com/shop/bushin...s/cadillac.php
If you have any questions, PM me. :nod:
Tools you'll need:
15mm socket
18mm socket
3/4" socket
Extensions
Wrapped headers FTW
