What is it Worth? - Flood damaged vehicle with Certificate of Destruction Title
FbodyAttraction
06-29-2012, 09:34 AM
My '02 Z28 was declared a total loss from a flood in TS Debby a few days ago. I took good care of it, and I was very saddened to see it go. The water got up to around the trim molding on the outside of the car, about halfway up the door. The interior is tear out, as it was soaked despite my attempts to dry it out.
Fortunately, the water didnt damage anything important, from what I could see. The car ran and drove fine after the flood, the A/C worked, the lights worked, the wipers worked, it was idling the same as ever.
The problem is that with a Certificate of Destruction, the car's VIN can never be put back on the road. You would have to turn this into an off-road vehicle, drag car or a autocross car. (however, I hear that you can register them in Kentucky...) What kind of price would you be willing to pay for this type of car????
Specs:
128,xxx miles
35th Aniversary edition Z28
Pewter Metalic
4 brand new 255/40/r17 tires (put on in march, about 3000 miles on the tires)
Dyno'd at ~392 HP about a year ago, tuned by EFI Alchemy in Green Cove Springs
Parts include:
C5 brake conversion w/ Baer Rotors, Hawk Pads
ASP Harmonic Balancer Crank Pulley
ASP Overdrive Alternator Pulley
SLP Airbox
TEA 5.3l Heads
ARP Head Bolts
Vinci Custom Grind Cam # 066 (220/224)
Crane 1.8 ratio LS1 Roller Rockers
Crane DIAGNOSTIC TUNER
Dynatech Stainless Headers # 700813
Dynatech SuperMaXX Catalyst-equipped 2.5” Y-pipe # 700815
Borla Exhaust System
LS7 Clutch & flywheel
BMR Subframe
Eldebrock Torque Arm
Summit Differential Cover
UMI Lower Control Arms
UMI Panhard Bar
UMI relocation Brackets
Aluminum Driveshaft
Bilstein SS shocks (8000 miles on them)
